I've seen the discussion of the (to me) bug that unlinking hosts on the template screen does not clear (or offer an option to), and see there are some patches for it (not sure if they apply to the latest version). But....
Is there a simple way to FIND these? You can search for untemplated items in the item display, but these also show LLD discovered items. That item display does not appear to let you filter LLD items, that I can see.
When people make this mistake, as I just did recently in a moment of forgetfulness, to dozens of hosts and a half dozen templates -- there are probably only a couple hundred items, easy to delete -- if I could get the item screen to actually list JUST them.
Am I missing a search criteria?
Or is falling back to SQL or API the only way?
