Font size in widgets HELP!
  • Ristoo
    • Jan 2023
    Hi, I am having a problem with my Zabbix dashboard and I am unsure of how to fix it. My boss asked me two days ago if I could increase the font size on the widgets in the dashboard. I initially thought it would be a simple task, but I have not been able to find a solution after searching the internet. One member in my regional Facebook group suggested that I need to write my own modules, but I have no experience with this. I also found files in the Zabbix location (/usr/share/zabbix/assets/styles) such as dark-theme.css and hc-dark.css. I am considering editing these files, but they are quite large. I would greatly appreciate any ideas or suggestions. Have a nice day, thanks.
  • coda_matt
    • Nov 2022
    • 20
    I don't know if there's a way of doing this in Zabbix itself, but here are a couple of ways to increase font size if you need a big screen in the office:
    • Try to "zoom in" using the browser (Ctrl + on Firefox)
    • Change the default font size in the browser (mine was 16, I tried 24) - you might need to edit your dashboard to suit a larger font
    • UniformEric
      • Sep 2025
      I have the same problem auto login with guest is working on our bigger dashboard screen.
      But everything is to small, I can zoom in to 140 %, then it's perfect. But after reboot it's gone.
      Is it possoble to enter a zoom level in the URL, like to enter a username?
