Application in templates
  • gferradas
    • Jan 2023
    • 24
    Hi im doing a course in udemy for zabbix and when i go to templates the tab applications does not exist the zabbix used in the course is 3.4.12 but i wanted to ask if the tab has been removed or is it somewhere else
    PD: im using zabbix 6.0.14 forget to mention it before
  • LenR
    • Sep 2009
    • 1010
    Applications moved to tags named Application with the value of the old application.
      • 4963
      They were converted to tags named Application, when upgrading your older version..
      But "the issue" ? No issue, just evolving in product... applications were deprecated and removed. You can get similar functionality with a use of tags.
      • LenR
        • Sep 2009
        • 1010
        When you switch versions, you really need to read the "Changes" section in the doc for EVERY version from old to new, In your case, 3.4.12 thru 6.0.14, then there are fewer surprises. There are changes and if you don't read what's new, you only exploit the product at the arcane level. They put new stuff in there to help us, not hide things
