Change in Trigger dependency behavior between 5.4.12 and 6.2.6?
  • bradturnbough
    • Apr 2020
    • 22
    I have two templates.
    Template A -
    Contains ITEM - Ping.
    Trigger for PING
    Template B -
    Contains ITEM - Zabbix Server Process Run Length (in minutes)
    Trigger for Zabbix Server Process Run Length.
    I can assign both templates to my zabbix server and they both work great.
    When I attempt to create a trigger dependency from Template A to Template B (Ping depends on Zabbix Process run length) I get this:
    • Trigger "{HOST.NAME} - Host cannot be pinged for 3m." cannot depend on the trigger "{HOST.NAME} - Zabbix Server Process has not been running for 30 minutes or more." from the host "SERVERNAME", because dependencies on triggers from a child template or host are not allowed.
    These templates are completely separate from one another, and they are also not linked in any other way.
    ***** THIS WORKS JUST FINE IN ZABBIX 5.4.12, and every version before it.******************
    When did this behavior change occur and why?
