Host not working after re-enabling them
  • Stian
    • Jan 2023
    Hi , i have an issue im not able to resolve, when i first start the Zabbix service on a host it autoregisters and sends data based on templates set just fine. But if i disable a host and then re-enable them it no longer sends any data and remains "unknown" in the zabbix fronted. If i delete the host and restart the service it works just fine again.
    The following shows up in the logs:
    cannot send list of active checks to "": host [] not monitored
  • Stian
    • Jan 2023
    bumppppp
    • Markku
      • Sep 2018
      • 1784
      What is your Zabbix version? See the release notes in https://www.zabbix.com/release_notes, do you see any updates or information about fixes that could match your problem?
      Markku
      • Stian
        • Jan 2023
        Can't find any that matches my issue, im running 6.2.0.
