Change number of basic DB connections for zabbix
  • poco
    • Jan 2023
    ​Zabbix is built with container and server version is 5.0.24.
    DB is using AWS RDS (mysql8.0).
    If we build multiple zabbix servers, we will run out of RDS connections. (Current max connections = 61)
    Basically, the number of connections from zabbix-server to DB is 25~35. Is there any way to reduce this?
    I know how to increase the max number of DB connections, but what I want to know is how to reduce the number of connections from zabbix to db.​
    ​​​​​​​Click image for larger version
Name:	スクリーンショット 2023-01-12 19.22.50.png
    HTML Code:
    mysql> show processlist;
    | Id  | User            | Host                | db          | Command | Time | State                  | Info             |
    |   5 | event_scheduler | localhost           | NULL        | Daemon  | 1850 | Waiting on empty queue | NULL             |
    |  12 | rdsadmin        | localhost:38868     | NULL        | Sleep   |    8 |                        | NULL             |
    |  72 | zabbix          | 10.11.100.135:30890 | zabbix50000 | Sleep   |   44 |                        | NULL             |
    |  74 | zabbix          | 10.11.100.135:30914 | zabbix50000 | Sleep   |    8 |                        | NULL             |
    |  75 | zabbix          | 10.11.100.135:30924 | zabbix50000 | Sleep   |   11 |                        | NULL             |
    |  76 | zabbix          | 10.11.100.135:30940 | zabbix50000 | Sleep   |    5 |                        | NULL             |
    |  77 | zabbix          | 10.11.100.135:30952 | zabbix50000 | Sleep   |  125 |                        | NULL             |
    |  78 | zabbix          | 10.11.100.135:30956 | zabbix50000 | Sleep   |    4 |                        | NULL             |
    |  79 | zabbix          | 10.11.100.135:30962 | zabbix50000 | Sleep   |    7 |                        | NULL             |
    |  80 | zabbix          | 10.11.100.135:30972 | zabbix50000 | Sleep   |    9 |                        | NULL             |
    |  81 | zabbix          | 10.11.100.135:30988 | zabbix50000 | Sleep   |    8 |                        | NULL             |
    |  82 | zabbix          | 10.11.100.135:31002 | zabbix50000 | Sleep   |    1 |                        | NULL             |
    |  83 | zabbix          | 10.11.100.135:31022 | zabbix50000 | Sleep   |    2 |                        | NULL             |
    |  84 | zabbix          | 10.11.100.135:31026 | zabbix50000 | Sleep   |   10 |                        | NULL             |
    |  85 | zabbix          | 10.11.100.135:31006 | zabbix50000 | Sleep   |   12 |                        | NULL             |
    |  86 | zabbix          | 10.11.100.135:31038 | zabbix50000 | Sleep   |    3 |                        | NULL             |
    |  87 | zabbix          | 10.11.100.135:31042 | zabbix50000 | Sleep   |    6 |                        | NULL             |
    |  88 | zabbix          | 10.11.100.135:31052 | zabbix50000 | Sleep   |   44 |                        | NULL             |
    |  89 | zabbix          | 10.11.100.135:31064 | zabbix50000 | Sleep   |    3 |                        | NULL             |
    |  90 | zabbix          | 10.11.100.135:31072 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    |  91 | zabbix          | 10.11.100.135:31086 | zabbix50000 | Sleep   |    2 |                        | NULL             |
    |  92 | zabbix          | 10.11.100.135:31098 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    |  93 | zabbix          | 10.11.100.135:31106 | zabbix50000 | Sleep   |  148 |                        | NULL             |
    |  94 | zabbix          | 10.11.100.135:31112 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    |  95 | zabbix          | 10.11.100.135:31116 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    |  96 | zabbix          | 10.11.100.135:31130 | zabbix50000 | Sleep   |  149 |                        | NULL             |
    |  97 | zabbix          | 10.11.100.135:31136 | zabbix50000 | Sleep   |  159 |                        | NULL             |
    |  98 | zabbix          | 10.11.100.135:31140 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    | 100 | zabbix          | 10.11.100.135:31158 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    | 101 | zabbix          | 10.11.100.135:31152 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    | 102 | zabbix          | 10.11.100.135:31172 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    | 103 | zabbix          | 10.11.100.135:31180 | zabbix50000 | Sleep   |  164 |                        | NULL             |
    | 104 | zabbix          | 10.11.100.135:31186 | zabbix50000 | Sleep   |    1 |                        | NULL             |
    | 105 | zabbix          | 10.11.100.135:31188 | zabbix50000 | Sleep   |   61 |                        | NULL             |
    | 106 | zabbix          | 10.11.100.135:31204 | zabbix50000 | Sleep   |   62 |                        | NULL             |
    | 120 | admin           | 10.11.0.187:32822   | NULL        | Query   |    0 | init                   | show processlist |
  • Answer selected by poco at 14-01-2023, 16:54.
    Hamardaban
    • May 2019
    • 2714
    StartDBSyncers ?
    StartODBCPoller ?
    • poco
      poco commented
      I used StartDBSyncers
      As a result, I found that it can be reduced to 25->21.
      Thank you.
  • Hamardaban
    • May 2019
    • 2714
    StartDBSyncers ?
    StartODBCPoller ?
    • poco
      poco commented
      Thank you.
