No Suppress Option
  • Ruiiur.Sys
    • Jan 2023
    No Suppress Option
    I'm new to Zabbix, in my configuration there's no "Suppress" checkbox when I "Update Problem", where can I enable it?
    Regards.
  • Hamardaban
    • May 2019
    • 2714
    1) The picture is so small that nothing is visible.
    2) Which version of Z are you using?
    • Ruiiur.Sys
      • Jan 2023
      Hi Hamardaban
      Uploaded new picture.
      The version of zabbix is 6.0.4
        Upgrade to version, that has it.. (6.2)..:P
