Continue with the next JSONPath if first fails (Preprocessing)
  • smarco
    • Jan 2023
    Hey guys!
    I am using my scripts on many servers​...
    Example:
    Preprocessing contain a JSONPath like
    $.status.value
    Recently on some nodes I have different output, but I don't want to duplicate dozens of scripts and templates.
    I'm looking for a way to pass to the next JSONPath if the first one doesn't contain those keys​.
    A "Custom on fail" -> "Set value to" -> SOURCE would be ideal​, but it seems to be not possible​.
    Is there a solution, a unique JSONPath with both, something​ with JS, or other?
    Thank you !!
    • 5002
    I think your only way would be to do some JS preprocessing first to normalize data and then continue with jsonpath...
    • smarco
      • Jan 2023
      I preferred to ask if there are already native methods...
      Done with JS! Thank you!
