How to sum multiple Switch Ports for a Link Label
  • jca001
    • Dec 2022
    I have a Managed Switch with multiple connections to a Server as a LAGG (Link Aggregation). The Macros I have in the Label now are:
    IN2: {?last(/Rack Switch/net.if.in[ifInOctets.49154])}
    IN3: {?last(/Rack Switch/net.if.in[ifInOctets.49155])}
    How can I add the 2 values to provide the Total of both connections?
  • Hamardaban
    • May 2019
    • 2714
    You need to create a calculated item in which to summarize the items you need
    After that, use the value in the link label.
    • jca001
      • Dec 2022
      How do I do that?
      • fvilarnovo
        • Jan 2023
        • 17
        Hi, here you have an example and explanation about how to create calculated items:
        https://blog.zabbix.com/zabbix-monit...xplained/9950/
        • jca001
          • Dec 2022
          Thanks for the quick reply. I will give that a try.
