How to Change the Default timeout(30) of "Multiple PROBLEM events generation"
  • Saravanan
    • Apr 2016
    Hi Folks,
    I'm just new to Zabbix forum ,
    Just want to receive multiple alerts for single event but in regular interval Eg:- 2 mins once , But here in zabbix it's sending emails at the interval of 30sec. Suggest how to change this value or how to achieve this scenario if it is possible .
    Thanks in advance !
  • marc55
    • Sep 2014
    • 18
    hi,
    May be, just change the item frequency related to that trigger at 2 minutes
    Regards
    • Saravanan
      • Apr 2016
      No Luck !
      Hi Marc55,
      Thanks for reply , By changing of the frequency of the items doesn't work Even we tried to adjust the duration value on the actions (actions-->conditions-->email duration), but no luck !
      • marc55
        • Sep 2014
        • 18
        Hi this is strange,
        I changed the frequency to 5 minutes with multiple problem trigger set, and I get a new trigger every 5 minutes.
        For me a trigger is computed each time a new value is received by zabbix.
        Regards
