Problem with LLD macros and JSON without indexes
  • Oscar Garcia
    • Oct 2015
    Hello all. We have Zabbix 5.0 LTS.
    We obtain the following JSON data through a REST service:
      "content": [
          "type": "TYPE",
          "availableHostnames": [
            "host1",
            "host2",
            "host3",
            "host4"
    We are using the following Preprocesing JSONPath:
    $.content[?(@.type == "TYPE")].availableHostnames.first()
    And tried the following LLD Macros:
    $.first() (0 items generated)
    $.[*] (0 items generated)
    $.. (error parsing JSONPath)
    $. (error parsing JSONPath)
    But neither works to assign the content of each element obtained in the JSON to a LLD macro.
    (*) We have also tried using the rule without "first()" and "$.first()", but it discovers a single element whose macro value is ["host1","host2","host3","host4"].
    How can I get the data for each element contained in the "availableHostnames" attribute so that each one creates a discovered item?
    Tested combinations:
    • Preprocessing step (JSONPath): $.content[?(@.type == "TYPE")].availableHostnames.first()
      • LLD Macro {#TEST} (result):
        • $. (Cannot process LLD macro "{#TEST}": jsonpath was unexpectedly terminated.).
        • $.. (Cannot process LLD macro "{#TEST}": jsonpath was unexpectedly terminated.).
        • $.first() (0 items created)
        • Code:
          (0 items created)
        • Code:
          (1 item created):
          • Ping ["host1","host2","host3","host4"] (icmpping["["host1","host2","host3","host4"]"])
        • $.first() (1 item created):
          • Ping host1 (icmpping[host1])
    I attach test host: zbx_export_TEST LLD.xml
    Thank you very much for your help.​
    • 5002
    gives you result
    "host1",
    "host2",
    "host3",
    "host4"
    kind of double array (not my real topic, I always confuse those arrays, element and objects.. ) so you probably should refer to inner one in LLD path as $.[0]. At least if I test here https://www.javainuse.com/jsonpath it works... if you use[*] it will return everything unchanged...
    and you cannot really use first(), as it limits to first object, but you need all of them...
    • Oscar Garcia
      • Oct 2015
      gives you result
      If i use $.[0] then only the first element appears as discovered item. Using $.[1] the second one, and so on.
      I need to discover 4 items, an element with each element of the array (ping host1, ping host2, ping host3, ping host4).
      Thank you for answer.
      • Oscar Garcia
        • Oct 2015
        Any ideas? Thanks.
