Problem updating Zabbix to version 6
  • tombaz47
    • Jan 2023
    • 16
    I have attempted updating Zabbix from version 5 to version 6 as per the installation instructions, however I get the following error:
    Upon looking at the logs, I appear to have the following which may be causing this:
    Error: Transaction test error:
    file /etc/zabbix/zabbix_server.conf from install of zabbix-server-mysql-6.2.6- release1.el8.x86_64 conflicts with file from package zabbix-server-pgsql-5.0.26- 1.el8.x86_64
    file /usr/share/man/man8/zabbix_server.8.gz from install of zabbix-server-mysq l-6.2.6-release1.el8.x86_64 conflicts with file from package zabbix-server-pgsql -5.0.26-1.el8.x86_64​
    I have attached the installation log for reference.
    Please can someone help me on this.
  • LenR
    • Sep 2009
    • 1011
    Are you using mysql or postgres? The error is mixed packages, you're trying to install server-mysql but server-pgsql for 5.0 is installed. The frontend error is because the database hasn't been updated, because a 6.0 zabbix_server hasn't started and upgraded the DB.
    • tombaz47
      • Jan 2023
      • 16
      Have ran the following command to check: cat /etc/zabbix/web/zabbix.conf.php
      <?php
      // Zabbix GUI configuration file.
      $DB['TYPE'] = 'POSTGRESQL';
      $DB['SERVER'] = 'localhost';
      $DB['PORT'] = '0';
      $DB['DATABASE'] = 'zabbix';
      $DB['USER'] = 'zabbix';
      • Atsushi
        • Aug 2013
        • 2028
        If you are using PostgreSQL, upgrade using zabbix-server-mysql-6.2.6 instead of zabbix-server-mysql-6.2.6. After upgrading the package and checking the configuration file, start zabbix_server and the database will be upgraded automatically. Once the upgrade process is finished, you should be able to access it from your web front end.
        • tombaz47
          • Jan 2023
          • 16
          I have tried that but am still getting the error. Anything else I can try?
          [root@MGMT-MON01 ~]# systemctl stop zabbix-server
          [root@MGMT-MON01 ~]# systemctl stop zabbix-proxy
          Failed to stop zabbix-proxy.service: Unit zabbix-proxy.service not loaded.
          [root@MGMT-MON01 ~]# mkdir /opt/zabbix-backup/
          mkdir: cannot create directory ‘/opt/zabbix-backup/’: File exists
          [root@MGMT-MON01 ~]# dnf upgrade zabbix-server-pgsql zabbix-web-pgsql zabbix-agent
          Invalid configuration value: failovermethod=priority in /etc/yum.repos.d/datto-rpm-repo-el.repo; Configuration: OptionBinding with id "failovermethod" does not exist
          Last metadata expiration check: 0:33:40 ago on Wed 18 Jan 2023 09:27:20 GMT.
          Dependencies resolved.
          Package Arch Version Repository Size
          Upgrading:
          zabbix-agent x86_64 6.2.6-release1.el8 zabbix 550 k
          zabbix-server-pgsql x86_64 6.2.6-release1.el8 zabbix 1.7 M
          Transaction Summary
          Upgrade 2 Packages
          Total download size: 2.2 M
          Is this ok [y/N]: y
          Downloading Packages:
          (1/2): zabbix-agent-6.2.6-release1.el8.x86_64.r 422 kB/s | 550 kB 00:01
          (2/2): zabbix-server-pgsql-6.2.6-release1.el8.x 1.0 MB/s | 1.7 MB 00:01
          Total 1.4 MB/s | 2.2 MB 00:01
          Running transaction check
          Transaction check succeeded.
          Running transaction test
          The downloaded packages were saved in cache until the next successful transaction.
          You can remove cached packages by executing 'dnf clean packages'.
          file /etc/zabbix/zabbix_server.conf from install of zabbix-server-pgsql-6.2.6-release1.el8.x86_64 conflicts with file from package zabbix-server-mysql-5.0.26-1.el8.x86_64
          file /usr/share/man/man8/zabbix_server.8.gz from install of zabbix-server-pgsql-6.2.6-release1.el8.x86_64 conflicts with file from package zabbix-server-mysql-5.0.26-1.el8.x86_64
          zz0.z1t7y8rixkzz
          • Atsushi
            • Aug 2013
            • 2028
            Wasn't it the Zabbix server for PostgreSQL that you were using? If you were not using Zabbix server for MySQL, please remove zabbix-server-mysql before upgrading zabbix-server-pgsql. Back up your configuration files before you begin.
