Juniper Inbound and Outbound Interface Errors
  • jtinsley88
    • Jan 2023
    New to Zabbix. I am using Juniper gear with 1G, 10G, and 100G Interfaces throughout my network. I have been trying to find a solid network monitor to monitor Interface errors. I am using the Juniper SNMP Template. The default Problem Expression for the High error rate trigger looks accurate as I do want to know within the last 5 minutes if there are any Inbound or Outbound Errors on any interface. However, what does the Recovery expression of " {$IF.ERRORS.WARN:"{#IFNAME}"}*0.8 " mean?
    I would like the Recovery to be when Zabbix sees "ZERO" interface errors. If there are any errors detected, I will be clearing the Interface errors anyways throughout troubleshooting and maintenance to make sure the Interface doesn't have any errors once we stabilize the Interface.
    Can I get a Recovery Expression for when the Interface has "ZERO" errors?
    Thanks!
