monitoring windows 10 using zabbix
  • nono1108
    • Jan 2023
    hello dear
    I want to monitor my PC using windows, what steps should I take? explanation please. thank you​
    • 5002
    First steps you should take would be reading the manual... https://www.zabbix.com/documentation/current/en/manual
    • jusavard
      • Sep 2013
      • 48
      Install the zabbix server on a Linux host (should be done by now), then download the user agent here (https://www.zabbix.com/fr/download_agents), install it, then configure it (Usually you just have to replace the Server, ServerActive and Hostname value), then (re)start it in your windows services.
      Pretty much it...​
