Hello
I'm tryng to configure the auto-registration on a Zabbix server using the API, but I'm experiencing some problems.
Here the json file:
used with the command:
The output is :
What's wrong with the json file?
I'm using Zabbix 2.2.
Thanks in advance,
Giovanni
Here the json file:
"jsonrpc": "2.0",
"method": "action.create",
"params": {
"name": "Auto registration",
"eventsource": 2,
"status": 0,
"esc_period": 120,
"operations": [
"operationtype": 6,
"optemplate": [
"templateid": "10001"
"auth": "<login-token>",
"id": 2
curl -k -H "Content-Type: application/json" -X POST --data @autoregistration.json https://zabbix-fronted:443/api_jsonrpc.php
{"jsonrpc":"2.0","error":{"code":-32602,"message":"Invalid params.","data":"Incorrect parameter for action \"Auto registration\"."},"id":2}
Thanks in advance,
Giovanni
