Web Monitoring XML POST
  • ralphmyers
    • Mar 2007
    Howdy,
    Is it possible to set up a web scenario with XML in the POST request? If so, what's the format for the request? Here's what I'm trying to no avail:
    <?xml version='1.0' encoding='utf-8'?><request date='12/12/2012 3:38:02 PM' type='evaluate' project-name='TestService'> <initializers /> <dataset> </dataset> <goals> <goal name='TEST GOAL' /> </goals> <options> <option name='com.testengine.eval.optimistic' value='no' /> <option name='com.testengine.debug.tree' value='off' /> </options></request>
  • Efitzgerald
    • Apr 2016
    I'm having similar problems. The documentation doesn't cover this (XML POST options) and I've googled around without finding anyone doing something similar. Can anyone help out?
    • lpossamai
      • Jun 2018
      • 119
      Were you guys able to get this working? I'm also looking for it.
      • kernbug
        • Feb 2013
        • 329
        Originally posted by ralphmyers
        Howdy,
        Zabbix rely on the curl library, you can try to set:
        Post field with you xml post string formatted for curl;
        Headers field with "Content-Type: application/somexml";
