Suppress sending recovery/ok email on certain triggers
  • Spinat
    • Jan 2023
    Is it possible to only send the "problem" email and suppress sending the recovery for triggers on ex. eventlogs?
    • 4997
    Never tried to avoid closing of events.. But if you have separate action for them and leave out "recovery operation", then it might work... Never actually tried it..:P
    • Spinat
      • Jan 2023
      Yes, I guess thats one way to avoid the closing events I just like keeping every alert conditions in only one trigger action, but i can live with two trigger actions. Thanks for your reply
