monitoring US-48-500W and US-16-XG or any new unify device
  • pepek
    • Nov 2022
    • 9
    hello all,
    please help i'm despair, i'm trying to monitor 2 mention devicec. I'm Able to monitor network ports information and temperature.
    but i'm not able to monitor CPU, memory and fun, all documentations that i found is pointing toFROGFOOT-RESOURCES-MIB OID starting with :1.3.6.1.4.1.10002.....
    but on my device snmpwalk can find any object available for this OID.
    PLS does anyone have any experiance with monitoring unifi switchies and can help ??
    thank you​
    • 4985
    cpu, memory etc are probably just regular snmpv2 mibs...
    is this one not working for you ? https://www.zabbix.com/integrations/ubiquiti
    • pepek
      • Nov 2022
      • 9
      i try that one, and switchis and they are using FROGFOOT-resources-MIB, i got error :
      i copy FROGFOOT MIB to /usr/share/snmp/mibs/ and nothing hanpend, still same error, and i'm getting same error as well wen i try snmpwalk with same OID as it is in CPU utilizations item :
      any other suggestion ?
        • 4985
        Of course there is no help from this, as it only gives you option to use textual OID-s instead of numeric ones... It does absolutely nothing for that device. Your issue is not in Zabbix, but in your devices, Maybe they are not configured to respond to certain queries? I have no knowledge of those devices whatsoever, so you need to dig into docs there.. For what I have managed to read in this short time, those boxes seem to have that issue of not showing any cpu etc since forever... like 8 years ...
        Here's one link, what gives some more links to MIB files, what you can try, https://medium.com/beyond-the-helpde...e-ac82ca1684c6
        But I doubt it helps, if your device is not giving out anything...
