tryinig to setup Zabbix proxy on openWRT with postgres DB
  • mikkiblue
    • Jan 2023
    I am tryinig to setup Zabbix proxy on openWRT (GL.iNET) with postgres DB. In GL.iNET repository there is only Zabbix version 4.0.16-3 vailable, but without zabbix-sql-scripts.
    How can I get proxy.sql for this release?
    I've used the latest and get the following error when starting the proxy:
    The proxy does not match Zabbix database. Current database version (mandatory/optional): 06020000/06020013. Required mandatory version: 04000000.​
    Find a suitable package from zabbix repo, extract needed scripts... http://repo.zabbix.com/zabbix/4.0/ I dont know what kind of packages openwrt uses..
    • Hamardaban
      • May 2019
      • 2714
      if the installed proxy uses the sqlite database, then it is enough to stop the service, delete the database file and start the service again.
      Database of the required version will be created.
      • mikkiblue
        • Jan 2023
        How can I configure zabbix_proxy to use SQLite database? I have dropped the postgress db, and set some path to a database file, but not shure if it will outomatically detect the right DB. Logs say ' connection to database <path to db> failed FATAL: database <path to db> does not exist. I've already tried both, without file, and with a file created by sqlite3 dommand.
        • Hamardaban
          • May 2019
          • 2714
          I'm sorry - I inattentively read the title of the topic and did not pay attention to what the database type is written there.
          In your case, you need to find in the distributions a script for creating a database exactly for your version (as cyber wrote)
          • mikkiblue
            • Jan 2023
            How can I view those files in folder .db?
