HowTo monitor a log file with a dinamic filename
  • gabrielglusgold
    • Apr 2021
    HowTo monitor a log file which name is the result value of another item? It is possible?
    Thanks in advance.
    • 5002
    No, you cannot use one items value in other items parameters.
    • Hamardaban
      • May 2019
      • 2714
      If the file name (not the path!) described by a regular expression, then you can try to use logrt or logrt.count https://www.zabbix.com/documentation...ypes/log_items
