Dashboard for ICMP ping ?
  • 86Zabbix
    • Jan 2023
    I've looked through a number of online articles and several help videos on creating dashboards, but none of them mention how to configure a basic ICMP check for devices. I'm trying to monitor the availability of devices which do not have the capability of installing a Zabbix agent and do not have the ability to configure SNMP. The only Interface options for the Widget are Zabbix Agent, SNMP, JMX, and IPMI. Is there a way to display the "Simple Check" type from the Device Item configuration into a widget on a Dashboard?
  • LenR
    • Sep 2009
    • 1010
    Use the ICMP Ping template on such devices. Devices that fail ping will have an alert, alerts will appear on the dashboard.
