disk usage trend
  • conehad
    • Jan 2023
    disk usage trend
    When i am looking at the disk space of my servers i just see a pie which informs me the current used en free diskp space. How is it possible to display the trends of hd usage. I did some searching and found this post.
    https://www.zabbix.com/forum/zabbix-...ard-disk-usage
    In this post the mention the following as a solution:
    Originally posted by reenville29607
    Click the Disk Reporter main window ribbon bar button.
    Use the Add Disks toolbar button to add one or more disks to the report. Disk space history will be tracked for each of the disks you add.
    Click the Save Disks button to save your disk report paths in the form of a text file.
    Close the Disk Reporter window.​
    But where can i find disk reporter main and disk toolbar?
    I am able to get the trends by creating a widget and then query the server in question and the trends of the disk usage ... but that is not the way to do it i guess, would like to see it as a stand graph like some other data.
    thanks in advance
