Discover VMware VMs -> Host prototypes -> add Group based on {#HV.ID} with .regsub
  • cowa
    • Jan 2023
    I would like to add a group to the "Discover VMware VMs".
    {#HV.ID} should use as a base, because I am not allowed to use regular user macros in LLD.
    For example, my {#HV.ID}:
    esxi07.lan.company.org
    esxi06.lan.company.org
    esxi2.lan.company.local
    I now want to cut everything up to the first point.
    Wished result:
    lan.company.org
    lan.company.org
    lan.company.local
    Unfortunately, all my attempts to do this with {{#HV.ID}.regsub(...)} failed.
    Is there someone who can create my regular expression for the REGSUB for me?​
    This was one of my many attempts:
    {{#HV.ID}.regsub([a-zA-Z]+,(\.[a-zA-Z]+)+)}
    Alternatively, I would prefer if I could give the groups of the hypervisor (parent) to Discovery VM (child). But I still have no idea how best to do this.
    Thanks for your help,
    Best Regards,
    Cornelius​
  • Answer selected by cowa at 01-02-2023, 10:59.
    cyber
    {{#HV.ID}.regsub("(.*?)\.(.*)",\2)}
    Explore and test this PCRE2 (PHP) regular expression online. Understand the pattern with regex explanations, generate code, and export matches to CSV or JSON.
    • cowa
      cowa commented
      regex is working! Thanks!
    • cowa
      cowa commented
  • cowa
    • Jan 2023
    Hello Cyber,
    thanks so much!
    I've been trying for more than 6 hours with no success.
    Now it works on ONE ESXi Hypervisor
    ​If I now execute this on an ESXI hypervisor, it works.
    When I execute it on a second ESXI hypervisor, I get the error message that the group already exists.​
    I think the Problem is, i added more esxi with the ending lan.company.org lile esx1.lan.company.org and esxi3.lan.company.org ...
    On each ESXi I added the templates "VMware" and "Template Virt VMware Hypervisor".
    Maybe my approach is wrong here?
    ​I guess I have to create a dummy host for all ESXi in a group.
    In this dummy host I link the template "VMware" as well as all ESXi as interface SNMP.​
    Since we have installations without vcenter(vcsa), I have to use the {VMware} variable for every ESXi Hypervisor separately ...
    In the variable {VMware}: "https://{HOST.IP}/sdk" I am not allowed to use {HOST.IP}, because this is a user macro.
    Only LLD macros are allowed there...
    Can you help me?
    I may have gotten a bit off track.​
    Best Regards,
    Cornelius
    • cowa
      • Jan 2023
      Now i add the dummy host and i think it is working, when i change the {vmware} Variable for every ESXi, but I am afraid that the "Discovery VMware VM" will then no longer be updated for the VM guests, since the LLD Discovery is in the dummy host.
        Just like hostnames, group names have to be unique, so if you have discovered those already from one, then it gives you error in another.
        • cowa
          • Jan 2023
          It is a confirmed critical bug.
          Anywhere have any experience how long it might take for the Zabbix team to fix critical bugs?
            as you saw.. that bugreport was created in 2014... has been around since versions 2.2...:P Zabbix has long lost the touch with their older bugs...
