Automatically add additional agent interfaces
  • ZabbixNoob
    • May 2016
    Ive been searching for a while and unable to find a definite answer.
    I have an app that has an integrated zabbix agent built in that we set to use a secondary port. Servers already have the primary installed for physical monitoring, the home made will only be used for application specific data.
    How do you add the second agent interface automatically to the host after its been auto discovered on the default zabbix agent?
    Thanks in advance,
