Inventory Hosts fields not filled
  • befehl
    • Feb 2023
    I just started with Zabbix 6.2.3 last week.
    Everything works well so far, but I don't get values from Host->Inventory displayed in the Inventory Tab.
    Host->Inventory is set to Automatic for all and I see the mapping e.g. from "Operating System" to "OS".
    I can see the Hosts at Iventory->Hosts but the field "OS" is not filled.
    Next try is to select the Host->Items->component os and select "Linux by Zabbix agent: Operating system".
    Selecting "Test" and "Get value" shows the value, so it works so far.
    On Items Tab of "Linux by Zabbix agent: Operating system" I select first "Clear history and trends" and then "Execute now" and "Update".
    But Inventory->Hosts the "OS" is still empty for the host.
    Next try is, going to Monitoring->Latest data and selecting my host and component os at Subfilter and then in the list below
    the checkbox for the host "Operating system" and select "Execute now". The response is "Request sent successfully".
    Back to Inventory->Hosts and the field OS is still empty.
    Any idea what else to try?
  • befehl
    • Feb 2023
    After trying many more possible solutions I finally have at least a work around by using "MassUpdate" and setting the fields used for Inventory to 30s. After about 1 minute all fields are updated and filled.
      is the field "Populates host inventory field" set appropriately? Or is there "none"
      • befehl
        • Feb 2023
        Yes, the field "Populates host inventory field" is set to "OS". I also tried different other inventory fields but no success.
        It feels like the change ist not propagated immediately. If I set the interval to 30 second it takes up to 1 minute.
        No wonder if I would set it back to 1 hour it might take up to 2 hours. That might be the case why I don't see any changes. But I haven't tested this. Just a guess.
          Nope... if it collects, then it populates right away... Maybe you have "discard unchanged with heartbeat" in item config? I think in such case, populating may take place only in case of change.... But I may be wrong also..
          • befehl
            • Feb 2023
            Indeed, the Items Preprocessing Tab has a Preprocessing step "Discard unchanged with heartbeat" set to one day ("1d"). But it is grayed out and I can't edit.
            Don't know when and how this was set. It must be active but how to disable it?
            Thanks for pointing this out.
              If it is grayed out on host level, then you need to edit it on template level... Or you just wait until next day...
              • befehl
                • Feb 2023
                I just changed on template level down to 1h which is good enough for me.
                Thank's for your help.
