Importing Templates from Zabbix 2.4 to 3.2
  • tekwreck
    • May 2016
    I get an error when importing templates.
    Cannot find value map "Host status" used for item "ICMP Ping" on "t_linux".
    Can anyone help with this?
  • Linwood
    • Dec 2013
    • 398
    Hopefully the 2.4 system is still available. Find the referenced value maps there (administration), and key into the new system, and then it should import.
    In 3.x systems valuemaps automatically export and import, but in the older systems you had to move them by hand.
