Zabbix 6 agent Repository - SSL certificate problem
  • jornell
    • Feb 2023
    • 18
    I'm trying to install the zabbix agent 6 on my SUSE12, but it shows me a certificate error, I have investigated but I can't find the solution, I also tried different SUSE servers and they show me the same error.
    If anyone can help me, I would be very grateful.
  • Atsushi
    • Aug 2013
    • 2028
    The SLES12 server certificate information you are using may be out of date. See the information at the URL below.
    • jornell
      • Feb 2023
      • 18
      To fix it, I had to remove the old certificate so I could update it with the "update-ca-certificates" command.
      thanks for the support.
