New host discovery and rules
  • wscarangello
    • Feb 2023
    I'm trying to setup my Zabbix 6.2 to scan a network range and automatically add the device into Zabbix, add it to the correct group, apply a template, enable the device. I'm using SNMP v2 to check and OID for the hostname. I'm pretty certain that the snmp portion is working because I can do and snmpwalk with the -v2c and the same community string and I get the desired hostname result. I feel like I'm not doing something correct in the setup of the Zabbix portion. I'm attaching screen caps of my discovery rules.
    I'm not even seeing any new hosts showing up in the Monitoring -> Discovery page either some I'm unsure of what could be going wrong.
