Auto Reg with Regex for hostname
  • wiliamL
    • Feb 2022
    • 28
    Trying to create a auto reg for linux and hostnames with dev in them. I have read a few posts but noone has posted the actual fix.
    Host metadata contains Linux
    Host name contains (?i)dev <--because dev can be captalized or lowercase. But this does not work.
    im guessing the syntax is not correct, but i have tried [Dd][Ee][Vv]
    conditionid:26 conditiontype:22 cond.value:'[Dd][Ee][Vv]' cond.value2:'' result:FAIL
    thanks in advance
  • LenR
    • Sep 2009
    • 1011
    Have you tried Host name Matches
    .*[dD][eE][vV].*
    The order of [dD] doesn't matter, I think you need the leading and trailing .*
      that "(?i)dev" regex should be ok.. https://regex101.com/r/KCQKtH/1
      But you need to use "Matches" instead of "contains"... "Contains" is the string to match, not regex. So it is taken literally as "(?i)dev" not as regex.
      https://www.zabbix.com/documentation...ration-actions
      Host name contains
      does not contain
      matches
      does not match
      Specify a host name or a host name to exclude.
      contains - host name contains the string.
      does not contain - host name does not contain the string.
      matches - host name matches regular expression.
      does not match - host name does not match regular expression.
      • wiliamL
        • Feb 2022
        • 28
        Both worked. I had the syntax incorrect. I was using contains and not match.
        Thank you both of you for replying. Much appreciated.
