Ironport Template for ESA
  • jay5c
    • Mar 2016
    • 16
    Hello Guys,
    I am looking for an ironport template to keep a check on Cisco ESA.
    Thank You
    Jay5c
    Tags : Ironport, Cisco, SNMP, ESA, Zabbix
  • LenR
    • Sep 2009
    • 1011
    Here is what I have: https://github.com/rugenl/sample_tem...t_template.xml
    • jay5c
      • Mar 2016
      • 16
      Originally posted by LenR
      Thank you for helping.
      While importing this template I got flagged with the message
      -Import Failed
      -Cannot find value map "SNMP Boolean" used for item prototype "Feature Key {#SNMPVALUE} is perpetual" of discovery rule "Feature Keys" on "Template_Ironport_LLD".
      Can you please help me with this ?
      Thanks a lot
      • LenR
        • Sep 2009
        • 1011
        Yea.... value maps should export with templates :-(
        That is the name of a value map with values 1 = True, 2 = False
        • jay5c
          • Mar 2016
          • 16
          Here is the process for importing zabbix template
          I go to Configuration >> Templates >> Create Template & give it name Template_ironport
          I check the box of Template_Ironport & click on import and choose the file from my PC (.xml) and import it.
          But when I again try to crosscheck the template by exporting, its blank (just with few lines giving detail about name and time)
          Can you please help
