Zabbix agent install issues
  • tim.stevenson
    • Feb 2023
    Hey all,
    I have been trying to install Zabbix agent on a windows server
    I went through the install and it failed (Only a tmp file in the install directory and the service in services) But now when I go to re install it I get this:
    Anyone have any ideas?
  • Michał Czerniakiewicz
    • Feb 2023
    • 17
    Hello Tim,
    You have to remove previous installation.
    1. Open Command Prompt as Administrator
    2. Go to Zabbix installation folder.
    cd\Program Files\zabbix\bin\win64
    3. Run the uninstall command
    zabbix_agentd.exe –uninstall
    4. Remove "zabbix_agentd.conf" and "zabbix_agentd" files​ from C:\
    5. Remove the whole folder from Program Files
    • tim.stevenson
      • Feb 2023
      Originally posted by Michał Czerniakiewicz
      Hello Tim,
      Managed to get it sorted somehow, Seemed like I also needed to remove the Service as the .exe was already not in the installation folder.
