Suppress specific warning (CPU utilization high) for some hosts during specific times
  • Flow
    • Nov 2021
    I want to suppress specific warning (CPU utilization high) for some hosts during specific times. The concrete case are low-CPU hosts performing their incremental backup every morning between 03:00-06:00. During these times i do not want to get "CPU utilization high" warnings, as they are expected.
    What would be the idiomatic Zabbix way to achieve this?
  • Answer selected by Flow at 08-02-2023, 13:57.
    Flow
    • Nov 2021
    The latter is what I ended up with. I have cloned the trigger, and added
    and not (time() > 030000 and time() < 070000)
    to the cloned trigger expression, and disabled then original trigger.
    • Okan
      Okan commented
      Hello ! I wanted to do the same and I did. It's working, thank you for your explanation.
    Either set a maintenance period for them, or redesign your trigger condition to include time() conditions. like ... and time()<030000 or time()>060000
    • Flow
      • Nov 2021
      • Okan
        Okan commented
