Active checks and log key
  • guest6936
    • Mar 2022
    • 25
    I am having some issues with the log key and I am not getting my head around it. I have created a Item that looks like this. For my testing instance I have done chmod 777 on /var/log/syslog.
    Despite this I am getting an alert that says: the "log" key is not supported in test or single passive check mode
    Fine, I googled this and I saw that I am required to use Active Checks so I updated my ServerActive and hostname parameters in the /etc/zabbix/zabbix-agent2.conf file accordingly.
    I have replaced our server IP-addresses to 8.8.8.8 and the hostname to myhiddenhostname.com
    # This is a configuration file for Zabbix agent 2 (Unix)
    # To get more information about Zabbix, visit http://www.zabbix.com
    ### Option: PidFile
    # Name of PID file.
    # Mandatory: no
    # Default:
    # PidFile=/tmp/zabbix_agent2.pid
    PidFile=/var/run/zabbix/zabbix_agent2.pid
    ### Option: LogType
    # Specifies where log messages are written to:
    # system  - syslog
    # file    - file specified with LogFile parameter
    # console - standard output
    # Mandatory: no
    # Default:
    # LogType=file
    ### Option: LogFile
    # Log file name for LogType 'file' parameter.
    # Mandatory: yes, if LogType is set to file, otherwise no
    # Default:
    # LogFile=/tmp/zabbix_agent2.log
    LogFile=/var/log/zabbix/zabbix_agent2.log
    ### Option: LogFileSize
    # Maximum size of log file in MB.
    # 0 - disable automatic log rotation.
    # Mandatory: no
    # Range: 0-1024
    # Default:
    # LogFileSize=1
    LogFileSize=0
    ### Option: DebugLevel
    # Specifies debug level:
    # 0 - basic information about starting and stopping of Zabbix processes
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - for debugging (produces lots of information)
    # 5 - extended debugging (produces even more information)
    # Mandatory: no
    # Range: 0-5
    # Default:
    # DebugLevel=3
    DebugLevel=4
    ### Option: SourceIP
    # Source IP address for outgoing connections.
    # Mandatory: no
    # Default:
    # SourceIP=
    ##### Passive checks related
    ### Option: Server
    # List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of Zabbix servers and Zabbix proxies.
    # Incoming connections will be accepted only from the hosts listed here.
    # If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
    # and '::/0' will allow any IPv4 or IPv6 address.
    # '0.0.0.0/0' can be used to allow any IPv4 address.
    # Example: Server=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
    # Mandatory: yes, if StartAgents is not explicitly set to 0
    # Default:
    # Server=
    Server=8.8.8.8
    ### Option: ListenPort
    # Agent will listen on this port for connections from the server.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # ListenPort=10050
    ### Option: ListenIP
    # List of comma delimited IP addresses that the agent should listen on.
    # First IP address is sent to Zabbix server if connecting to it to retrieve list of active checks.
    # Mandatory: no
    # Default:
    # ListenIP=0.0.0.0
    ### Option: StatusPort
    # Agent will listen on this port for HTTP status requests.
    # Mandatory: no
    # Range: 1024-32767
    # Default:
    # StatusPort=
    ##### Active checks related
    ### Option: ServerActive
    # Zabbix server/proxy address or cluster configuration to get active checks from.
    # Server/proxy address is IP address or DNS name and optional port separated by colon.
    # Cluster configuration is one or more server addresses separated by semicolon.
    # Multiple Zabbix servers/clusters and Zabbix proxies can be specified, separated by comma.
    # More than one Zabbix proxy should not be specified from each Zabbix server/cluster.
    # If Zabbix proxy is specified then Zabbix server/cluster for that proxy should not be specified.
    # Multiple comma-delimited addresses can be provided to use several independent Zabbix servers in parallel. Spaces are allowed.
    # If port is not specified, default port is used.
    # IPv6 addresses must be enclosed in square brackets if port for that host is specified.
    # If port is not specified, square brackets for IPv6 addresses are optional.
    # If this parameter is not specified, active checks are disabled.
    # Example for Zabbix proxy:
    # ServerActive=127.0.0.1:10051
    # Example for multiple servers:
    # ServerActive=127.0.0.1:20051,zabbix.domain,[::1]:30051,::1,[12fc::1]
    # Example for high availability:
    # ServerActive=zabbix.cluster.node1;zabbix.cluster.node2:20051;zabbix.cluster.node3
    # Example for high availability with two clusters and one server:
    # ServerActive=zabbix.cluster.node1;zabbix.cluster.node2:20051,zabbix.cluster2.node1;zabbix.cluster2.node2,zabbix.domain
    # Mandatory: no
    # Default:
    # ServerActive=
    ServerActive=8.8.8.8
    ### Option: Hostname
    # List of comma delimited unique, case sensitive hostnames.
    # Required for active checks and must match hostnames as configured on the server.
    # Value is acquired from HostnameItem if undefined.
    # Mandatory: no
    # Default:
    # Hostname=
    Hostname=myhiddenhostname.com
    ### Option: HostnameItem
    # Item used for generating Hostname if it is undefined. Ignored if Hostname is defined.
    # Does not support UserParameters or aliases.
    # Mandatory: no
    # Default:
    # HostnameItem=system.hostname
    ### Option: HostMetadata
    # Optional parameter that defines host metadata.
    # Host metadata is used at host auto-registration process.
    # An agent will issue an error and not start if the value is over limit of 255 characters.
    # If not defined, value will be acquired from HostMetadataItem.
    # Mandatory: no
    # Range: 0-255 characters
    # Default:
    # HostMetadata=
    ### Option: HostMetadataItem
    # Optional parameter that defines an item used for getting host metadata.
    # During an auto-registration request an agent will log a warning message if
    # the value returned by specified item is over limit of 255 characters.
    # This option is only used when HostMetadata is not defined.
    # Mandatory: no
    # Default:
    # HostMetadataItem=
    ### Option: HostInterface
    # Optional parameter that defines host interface.
    # Host interface is used at host auto-registration process.
    # If not defined, value will be acquired from HostInterfaceItem.
    # Mandatory: no
    # Default:
    # HostInterface=
    ### Option: HostInterfaceItem
    # Optional parameter that defines an item used for getting host interface.
    # This option is only used when HostInterface is not defined.
    # Mandatory: no
    # Default:
    # HostInterfaceItem=
    ### Option: RefreshActiveChecks
    # How often list of active checks is refreshed, in seconds.
    # Mandatory: no
    # Range: 60-3600
    # Default:
    # RefreshActiveChecks=120
    ### Option: BufferSend
    # Do not keep data longer than N seconds in buffer.
    # Mandatory: no
    # Range: 1-3600
    # Default:
    # BufferSend=5
    ### Option: BufferSize
    # Maximum number of values in a memory buffer. The agent will send
    # all collected data to Zabbix Server or Proxy if the buffer is full.
    # Option is not valid if EnablePersistentBuffer=1
    # Mandatory: no
    # Range: 2-65535
    # Default:
    # BufferSize=100
    ### Option: EnablePersistentBuffer
    # Enable usage of local persistent storage for active items.
    # 0 - disabled, in-memory buffer is used (default); 1 - use persistent buffer
    # Mandatory: no
    # Range: 0-1
    # Default:
    # EnablePersistentBuffer=0
    ### Option: PersistentBufferPeriod
    # Zabbix Agent2 will keep data for this time period in case of no
    # connectivity with Zabbix server or proxy. Older data will be lost. Log data will be preserved.
    # Option is valid if EnablePersistentBuffer=1
    # Mandatory: no
    # Range: 1m-365d
    # Default:
    # PersistentBufferPeriod=1h
    ### Option: PersistentBufferFile
    # Full filename. Zabbix Agent2 will keep SQLite database in this file.
    # Mandatory: no
    # Default:
    # PersistentBufferFile=
    ############ ADVANCED PARAMETERS #################
    ### Option: Alias
    # Sets an alias for an item key. It can be used to substitute long and complex item key with a smaller and simpler one.
    # Multiple Alias parameters may be present. Multiple parameters with the same Alias key are not allowed.
    # Different Alias keys may reference the same item key.
    # For example, to retrieve the ID of user 'zabbix':
    # Alias=zabbix.userid:vfs.file.regexp[/etc/passwd,^zabbix:.:([0-9]+),,,,\1]
    # Now shorthand key zabbix.userid may be used to retrieve data.
    # Aliases can be used in HostMetadataItem but not in HostnameItem parameters.
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Timeout
    # Spend no more than Timeout seconds on processing
    # Mandatory: no
    # Range: 1-30
    # Default:
    # Timeout=3
    ### Option: Include
    # You may include individual files or all files in a directory in the configuration file.
    # Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
    # Mandatory: no
    # Default:
    # Include=
    Include=/etc/zabbix/zabbix_agent2.d/*.conf
    # Include=/usr/local/etc/zabbix_agent2.userparams.conf
    # Include=/usr/local/etc/zabbix_agent2.conf.d/
    # Include=/usr/local/etc/zabbix_agent2.conf.d/*.conf
    ### Option:PluginTimeout
    # Timeout for connections with external plugins.
    # Mandatory: no
    # Range: 1-30
    # Default: <Global timeout>
    # PluginTimeout=
    ### Option:PluginSocket
    # Path to unix socket for external plugin communications.
    # Mandatory: no
    # Default:/tmp/agent.plugin.sock
    # PluginSocket=
    ### Option: UnsafeUserParameters
    # Allow all characters to be passed in arguments to user-defined parameters.
    # The following characters are not allowed:
    # Additionally, newline characters are not allowed.
    # 0 - do not allow
    # 1 - allow
    # Mandatory: no
    # Range: 0-1
    # Default:
    # UnsafeUserParameters=0
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # See 'zabbix_agentd' directory for examples.
    # Mandatory: no
    # Default:
    # UserParameter=
    ### Option: UserParameterDir
    # Directory to execute UserParameter commands from. Only one entry is allowed.
    # When executing UserParameter commands the agent will change the working directory to the one
    # specified in the UserParameterDir option.
    # This way UserParameter commands can be specified using the relative ./ prefix.
    # Mandatory: no
    # Default:
    # UserParameterDir=
    ### Option: ControlSocket
    # The control socket, used to send runtime commands with '-R' option.
    # Mandatory: no
    # Default:
    # ControlSocket=
    ControlSocket=/tmp/agent.sock
    ####### TLS-RELATED PARAMETERS #######
    ### Option: TLSConnect
    # How the agent should connect to server or proxy. Used for active checks.
    # Only one value can be specified:
    # unencrypted - connect without encryption
    # psk         - connect using TLS and a pre-shared key
    # cert        - connect using TLS and a certificate
    # Mandatory: yes, if TLS certificate or PSK parameters are defined (even for 'unencrypted' connection)
    # Default:
    # TLSConnect=unencrypted
    ### Option: TLSAccept
    # What incoming connections to accept.
    # Multiple values can be specified, separated by comma:
    # unencrypted - accept connections without encryption
    # psk         - accept connections secured with TLS and a pre-shared key
    # cert        - accept connections secured with TLS and a certificate
    # Default:
    # TLSAccept=unencrypted
    ### Option: TLSCAFile
    # Full pathname of a file containing the top-level CA(s) certificates for
    # peer certificate verification.
    # Mandatory: no
    # Default:
    # TLSCAFile=
    ### Option: TLSCRLFile
    # Full pathname of a file containing revoked certificates.
    # Mandatory: no
    # Default:
    # TLSCRLFile=
    ### Option: TLSServerCertIssuer
    # Allowed server certificate issuer.
    # Mandatory: no
    # Default:
    # TLSServerCertIssuer=
    ### Option: TLSServerCertSubject
    # Allowed server certificate subject.
    # Mandatory: no
    # Default:
    # TLSServerCertSubject=
    ### Option: TLSCertFile
    # Full pathname of a file containing the agent certificate or certificate chain.
    # Mandatory: no
    # Default:
    # TLSCertFile=
    ### Option: TLSKeyFile
    # Full pathname of a file containing the agent private key.
    # Mandatory: no
    # Default:
    # TLSKeyFile=
    ### Option: TLSPSKIdentity
    # Unique, case sensitive string used to identify the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKIdentity=
    ### Option: TLSPSKFile
    # Full pathname of a file containing the pre-shared key.
    # Mandatory: no
    # Default:
    # TLSPSKFile=
    ####### PLUGIN-SPECIFIC PARAMETERS #######
    ### Option: Plugins
    # A plugin can have one or more plugin specific configuration parameters in format:
    #     Plugins.<PluginName>.<Parameter1>=<value1>
    #     Plugins.<PluginName>.<Parameter2>=<value2>
    # Mandatory: no
    # Range:
    # Default:
    ### Option: Plugins.Log.MaxLinesPerSecond
    # Maximum number of new lines the agent will send per second to Zabbix Server
    # or Proxy processing 'log' and 'logrt' active checks.
    # The provided value will be overridden by the parameter 'maxlines',
    # provided in 'log' or 'logrt' item keys.
    # Mandatory: no
    # Range: 1-1000
    # Default:
    # Plugins.Log.MaxLinesPerSecond=20
    ### Option: AllowKey
    # Allow execution of item keys matching pattern.
    # Multiple keys matching rules may be defined in combination with DenyKey.
    # Key pattern is wildcard expression, which support "*" character to match any number of any characters in certain position. It might be used in both key name and key arguments.
    # Parameters are processed one by one according their appearance order.
    # If no AllowKey or DenyKey rules defined, all keys are allowed.
    # Mandatory: no
    ### Option: DenyKey
    # Deny execution of items keys matching pattern.
    # Multiple keys matching rules may be defined in combination with AllowKey.
    #       Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
    # Mandatory: no
    # Default:
    # DenyKey=system.run[*]
    ### Option: Plugins.SystemRun.LogRemoteCommands
    # Enable logging of executed shell commands as warnings.
    # 0 - disabled
    # 1 - enabled
    # Mandatory: no
    # Default:
    # Plugins.SystemRun.LogRemoteCommands=0
    ### Option: ForceActiveChecksOnStart
    # Perform active checks immediately after restart for first received configuration.
    # Also available as per plugin configuration, example: Plugins.Uptime.System.ForceActiveChecksOnStart=1
    # Mandatory: no
    # Range: 0-1
    # Default:
    # ForceActiveChecksOnStart=0
    # Include configuration files for plugins
    Include=./zabbix_agent2.d/plugins.d/*.conf
    Logs
    2023/02/07 12:39:12.123332 [101] In refreshActiveChecks() from [8.8.8.8:10051]
    2023/02/07 12:39:12.167572 [101] End of refreshActiveChecks() from [8.8.8.8:10051]
    2023/02/07 12:39:12.168785 [101] processing update request (0 requests)
    2023/02/07 12:39:12.168807 [101] skipping empty update for unregistered client
    Versions
    Zabbix 6.0.3
    Agents running zabbix_agent2 (Zabbix) 6.0.12
    Any help is appreciated.
  • guest6936
    • Mar 2022
    • 25
    Now I realised my mistake, and it was a stupid one. I didn't select the Active agent in my item.
    I will leave this for others to learn by my stupidity.
    2023/02/07 12:55:20.125056 [101] In refreshActiveChecks() from [8.8.8.8:10051]
    2023/02/07 12:55:20.166606 [101] End of refreshActiveChecks() from [8.8.8.8:10051]
    2023/02/07 12:55:20.166639 [101] processing update request (1 requests)
    2023/02/07 12:55:20.166647 [101] registering new client
    2023/02/07 12:55:20.166692 [101] adding new request for key: 'log[/var/log/syslog,asterisk]'
    2023/02/07 12:55:20.166797 [101] created exporter task for plugin 'Log' itemid:45009 key 'log[/var/log/syslog,asterisk]'
    However, I am still having the the "log" key is not supported in test or single passive check mode in the GUI.
    Update: now it appears to be doing stuff
    2023/02/07 13:00:09.001168 executing exporter task for itemid:45009 key 'log[/var/log/syslog,asterisk]'
    2023/02/07 13:00:09.001701 In process_logrt() flags:0x07 filename:'/var/log/syslog' lastlogsize:0 mtime:0
    2023/02/07 13:00:09.001740 In add_logfile() filename:'/var/log/syslog' mtime:0 size:10331431
    2023/02/07 13:00:09.001754 add_logfile() logfiles:0x7f066c001670 logfiles_alloc:64
    2023/02/07 13:00:09.001763 End of add_logfile()
    2023/02/07 13:00:09.002163 process_logrt() old file list:
    2023/02/07 13:00:09.002191    file list empty
    2023/02/07 13:00:09.002204 process_logrt() new file list: (mtime:0 lastlogsize:0 start_idx:0)
    2023/02/07 13:00:09.002221    nr:0 filename:'/var/log/syslog' mtime:0 size:10331431 processed_size:0 seq:0 copy_of:-1 incomplete:0 dev:66308 ino_hi:0 ino_lo:272801 md5_block_size:512 first_block_md5:391dd1848323b79b3169847fe4c5b4bb last_block_offset:10330919 last_block_md5:18dd4d0bd32005abb7be2419bec15375
    2023/02/07 13:00:09.002232 In process_log() filename:'/var/log/syslog' lastlogsize:0 mtime:0 seek_offset:0
    2023/02/07 13:00:09.004267 End of process_log() filename:'/var/log/syslog' lastlogsize:31406 mtime:0 ret:SUCCEED processed_bytes:31406
    2023/02/07 13:00:09.004293 End of process_logrt():SUCCEED
    2023/02/07 13:00:09.004325 executed exporter task for itemid:45009 key 'log[/var/log/syslog,asterisk]'
    2023/02/07 13:00:13.123614 [101] upload history data, 1/100 value(s)
    • guest6936
      • Mar 2022
      • 25
      I can see the logs now in my GUI. So I guess this one is solved. I hope someone can find joy in my misfortune.
      Anyhow I have one question, how should I solve so that the zabbix agent have permission to read from /var/log/syslog? For Ubuntu bases OS I just added the user zabbix to the group adm, perhaps this is the best approach.
