Zabbix RPM installation
  • damiancancela
    • May 2020
    • 14
    I want to install Zabbix using RPM's, download the RPM packages from https://repo.zabbix.com/zabbix/6.2/rhel/8/x86_64/ and then install them manually.
    Checking the documentation first I should deploy the release package, for example for 6.2 the latest is 6.2.3
    rpm -Uvh https://repo.zabbix.com/zabbix/6.2/z...el8.noarch.rpm
    and later the zabbix server / frontend rpm (whatever I need).
    My doubt here is, for example i want to install version 6.2.7 release but the latest release package is 6.2.3 (zabbix-release-6.2-3.el8.noarch.rpm). So is it possible to install release 6.2.3 and later 6.2.7 server and frontend packages?
    That will work? I dont know why there is no 6.2.7 release package in repo folder.
  • tim.mooney
    • Dec 2012
    • 1436
    You don't need the zabbix-release package at all if you're going to manually download the RPMs you need. The zabbix-release package just installs the repo file in /etc/yum.repos.d/ and the GPG public key used to sign the packages, for use with yum or dnf.
      Originally posted by Terew1988
      Hello
      To install Zabbix using RPM on a Red Hat-based system, add Zabbix repository, run yum makecache,
      then install Zabbix server/agent via yum install zabbix-server-mysql zabbix-web-mysql zabbix-agent.
      Configure DB and web UI, start and enable services.
      Did you at least read, what was thread starter's initial plan? No....
      • damiancancela
        • May 2020
        • 14
        That was it, thanks!
