Hi, I am currently monitoring a zimbra server with zabbix agent. I use userparameters to get "Running" as a grep from a tmp file. I have an issue when i update the tmp file on the zimbra server ,the zabbix agent cannot access it and it returns empty as a key value. How can i set a trigger where it only triggers when the last 2 or 3 readings came back not equal to "Running"?
​Thanks in advance
​Thanks in advance
