Failed to start Zabbix Agent - SUSE12
  • jornell
    • Feb 2023
    • 18
    Hello,I installed the zabbix agent on my SUSE12, however it won't let me start it.
    I have several SUSE12 servers that have the same problem, it tries to reinstall the agent but it keeps showing the error, also the servers cannot be restarted since they are in use and since the agent has never been started, the zabbix log folders are empty.
    • Example Server:
    ​​Click image for larger version
    Can anybody please help me? Im stuck at this point
    The 127 error code indicates “command not found”. This occurs when any given command within your Bash script or on Bash command line is not found in any of the paths defined by PATH system environment variable. The solution is to make sure that the command your are using can be found within your $PATH​
    What does journalctl say? What happens if you execute manually "/usr/sbin/zabbix_agentd -c <path to your conf file>"
    Missing config file?
    • jornell
      • Feb 2023
      • 18
      ​when executing journalctl and the service manually, it shows me an error with the libpcre2-8.so.0 library.
      ​ Click image for larger version
        Unsatisfied requirements to run agent...
        Agent
        libpcre/libpcre2 One of PCRE/PCRE2 library is required for Perl Compatible Regular Expression (PCRE) support.
        The naming may differ depending on the GNU/Linux distribution, for example 'libpcre3' or 'libpcre1'. PCRE v8.x and PCRE2 v10.x (from Zabbix 6.0.0) are supported.
        Required for log monitoring. Also required on Windows.
        Fix the issue and run your agent...
