simple trigger - dumb question
  • jdoggy31
    • Feb 2019
    • 39
    I have a simple trigger that works
    last(/Test/Test.Status)<>"Healthy"
    Im trying to add a simple time modifier wait 2 hours but the syntax is eluding me.. ​
    What do you mean with "wait 2 hours"? All values for last 2h have to not match "Healthy" ? (use find() instead) Or "there was a not "Healthy" value 2h ago? (use first(/host/key,2h) → retrieve the oldest value within the last 2 hours until now ) Or something else?
    • shoemakerawful
      • Feb 2023
      i think your syntax is wrong somewhere. You should double check the syntax.
      • jdoggy31
        • Feb 2019
        • 39
        Clarification -
        last(/Test/Test.Status)<>"Healthy"​ = triggers when any value in Test.status is anything other the Healthy, Now I'm trying to figure out how to modify it to not trigger until I have two hours straight of unhealthy checks, Im new and learning Zabbix so my knowledge of the syntax is not so great.​
