Proxmox VE / Node
  • ISSchuster
    • Feb 2023
    Proxmox VE / Node
    I just started with zabbix - looks great but I have a problem.
    When using the Proxmox VE via HTTP template it discovers and adds all Nodes from the Cluster. Thats good - and bad ;-)
    If this one host goes down the complete cluster monitoring goes down because the API is no longer reachable.
    If I add a second node I get every message twice.
    Can I somehow exclude the other nodes - so that one host only receives data for itself? And not for the other nodes?
    Proxmox Node 1 => only data for Node 1
    Proxmox Node 2 => only data for Node 2
    It should be really simple to filter the proxmox API output and only use data for a specific node....
    Any ideas?
    Thanks, Stefan
  • ISSchuster
    • Feb 2023
    Problem solved - I think.
    Added a filter to the Discovery Rules...
    Until now it's working as expected.
    • alxndro.plo
      alxndro.plo commented
      Stefan, tell me please, how you solved this problem?
  • guille.rodriguez
    • Jun 2022
    • 120
    Can you add the filter here to other people that have or will have same problem?
    • matsnlc
      • Feb 2023
      New to Zabbix and tried this template out. Not really sure how to set this up the best way for my nodes. Do I even need an agent installed on the actual node?
      Since it discovers and collects data for all nodes in a cluster by REST calls from Zabbix server I would more like to have a virtual cluster host (that gets it all) rather then a host for every node.
      Any best practice with this template? Should I setup discovery filters and have a host/node with API calls going to the specific node or should I setup more like a VIP that picks whatever node
      is working and report back to a virtual cluster host.
      --Mats
