Remote commands via Proxies
  • AntonMay
    • Feb 2023
    Good day
    So this is another remote commands issues, after reading all the posts and the documentation.
    All versions, agent, proxy and zabbix servers (in HA) are 6.2.
    I have two (2) proxies. I'm are trying to run remote commands to the proxies to execute. The commands are simple ping and traceroute commands to network devices.
    I have enabled the remote command on the agent on the proxies and logging.
    After reading the documentation I saw that remote commands can only be done by passive agents. - https://www.zabbix.com/documentation...remote_command
    Passive checks are enabled and ServerActive=0 in the zabbix_agent.conf
    The scripts are set to manual, so that the NOC's can execute the command.​
    But when trying to run the script to ping a network device the error "remote commands are not enable" pops up.
    ​​Is there anything that I'm missing?
