Discovery error
  • Xyue
    • Jan 2016
    • 93
    Discovery error
    Hi guys,
    I'm having the error message when creating discovery rules to discover temperature of cisco 4507. I'm using zabbix 3.0.
    FYI, 1.3.6.1.4.1.9.9.13.1.3.1.2 is the temperature description and 1.3.6.1.4.1.9.9.13.1.3.1.3 is the temperature value
    Error message
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[Air inlet]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[Air inlet remote]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[Air outlet]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[Air outlet remote]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[Stub A]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[Stub B]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[XPP]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[VFE]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[NFE]" already exists.
    Cannot create item: item with the same key "ciscoEnvMonTemperatureStatusValue[CPU]" already exists.
    Cannot create item: item with the same key "ciscoEnvM.....
    Discovery rules configuration
    Key : ciscoEnvMonTemperatureStatusDescr
    SNMP OID : discovery[{#SNMPVALUE},1.3.6.1.4.1.9.9.13.1.3.1.2]
    Discovery rule's Item
    Name : Temperature of $1
    Key : ciscoEnvMonTemperatureStatusValue[{#SNMPVALUE}]
    SNMP OID : 1.3.6.1.4.1.9.9.13.1.3.1.3.{#SNMPINDEX}
    Can anyone advise where i did the wrong ?
    Thank you very much in advance.
  • Xyue
    • Jan 2016
    • 93
    Hi Guys,
    I have figure out why the discovery always return error. I have run the OID through snmpwalk and found that the description are all the same.
    [root@zabsrv ~]# snmpwalk -v2c -c zabbix 10.32.250.20 1.3.6.1.4.1.9.9.13.1.3.1.2
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.1 = STRING: "Air inlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.2 = STRING: "Air inlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.3 = STRING: "Air outlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.4 = STRING: "Air outlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.11 = STRING: "Air inlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.12 = STRING: "Air inlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.13 = STRING: "Air outlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.14 = STRING: "Air outlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.41 = STRING: "Air inlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.42 = STRING: "Air inlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.43 = STRING: "Air outlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.44 = STRING: "Air outlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.51 = STRING: "Air inlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.52 = STRING: "Air inlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.53 = STRING: "Air outlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.54 = STRING: "Air outlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.61 = STRING: "Air inlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.62 = STRING: "Air inlet remote"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.63 = STRING: "Air outlet"
    SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.64 = STRING: "Air outlet remote"
    Can anyone advise me how to set this using discovery ?
    * I was able to setup the discovery if the description are different.
    • Xyue
      • Jan 2016
      • 93
      Hi Guys,
      I have sorted out how to discover since value are the same.
      In the discovery rules, i still let it discover the description although the value are the same.
      Discovery Rules
      I fine tune the name in the item. Instead of using the SNMPVALUE, i use the SNMPINDEX so it won't give me below error.
      After change the Name to SNMPINDEX, it shows as below which works fine.
      ciscoEnvMonTemperatureState[64]
      ciscoEnvMonTemperatureState[63]
      ciscoEnvMonTemperatureState[62]
      ciscoEnvMonTemperatureState[61]
      ciscoEnvMonTemperatureState[54]
      ciscoEnvMonTemperatureState[53]
      ciscoEnvMonTemperatureState[52]
      The configuration as below.
      Discovery Item
      Name : Temperature of {#SNMPINDEX}
      Key : ciscoEnvMonTemperatureState[{#SNMPINDEX}]
      OID : 1.3.6.1.4.1.9.9.13.1.3.1.6.{#SNMPINDEX}
      Hope this can help others who have the same error like me.
