Use proc_num to find processes with slightly differing names
  • UniLEDLS
    • Nov 2022
    • 11
    I have a template that checks if a particular process is running. 9 times out of 10, this process is called lednet.exe - However, in some instances, there will be a process that is lednet 1043.exe or lednet 1045.exe instead. I realise proc.num isn't regex compatible itself, but the cmdline is. Can anyone help with producing a regex string that would allow me to search if any of those similar processes are running? My regex skills are somewhat limited.
    lednet(.*)\.exe
    Explore and test this PCRE2 (PHP) regular expression online. Understand the pattern with regex explanations, generate code, and export matches to CSV or JSON.
