UserParameter trigger expression syntax
  • jrdnyquist
    • Jun 2007
    I created a UserParameter called "docker-mongodb.status" that sucessfully returns up or down...
    zabbix_get -k docker-mongodb.status -s 1.2.3.4 -p 10050
    up
    Now I am trying ti add a trigger expression but I canlt seem to figure out the syntax in Zabbix 6.0.13
    {<host.example.com>:docker-mongodb.status.str(down)}=1
    It returns this error...
    Invalid parameter "/1/expression": incorrect expression starting from "{<host.example.com>:docker-mongodb.status.str(down)}=1".
    What's the proper syntax here? ​​​​​​
  • guille.rodriguez
    • Jun 2022
    • 120
    Try with this
    find(/host_or_templatename/docker-mongodb.status,,"regexp",down)=1
    This is one trigger that I use to check if Windows Update is aiming to Internet Microsoft Windows Update instead internal Windows Upate Server (WSUS) service.
    find(/Template Windows Custom v2 active/WinWSUSServer,,"regexp",Internet)=1
