User Macro substitution at Web Scenario
  • markfree
    • Apr 2019
    • 875
    Zabbix 6.2
    In a template, I have a user macro for Web scenarios that I monitor.
    {$WEB_SERVICE} = HTTP or HTTPS
    I've added this macro to the scenario name, step name and step URL.
    Click image for larger version  Name:	image.png Views:	0 Size:	5.4 KB ID:	459701
    Click image for larger version  Name:	image.png Views:	0 Size:	8.1 KB ID:	459700​
    Now, Zabbix is collecting data correctly with this macro.
    However, at host level, Latest Data shows the Web Scenario items with the macro name instead of its value. The same for the step name.
    Only the web item keys are showing the actual macro value.
    Click image for larger version  Name:	image.png Views:	0 Size:	24.1 KB ID:	459698
    Click image for larger version  Name:	image.png Views:	0 Size:	33.3 KB ID:	459699​
    I was under the impression that this macro would be substituted at the host level, but it was not.
    Any tips on that?​
  • Hamardaban
    • May 2019
    • 2714
    Custom macros are no longer supported in the naming of items.
    You can use lld to create items titles with the desired text.
    • markfree
      • Apr 2019
      • 875
      Thanks, Hamardaban .
      Unfortunately, there are no Web Scenario prototypes.
