Can i use on-premises Zabbix Server for Azure and AWS
  • imtiaza
    • Feb 2023
    Dear Gurus,
    I have Zabbix server installed on-premises on CentOS 8 Stream.
    I want to monitor my Azure and AWS resources, can i use this server for that ?
    Your kind support would be highly appreciated.
    FOR AZURE AND AWS means, can i monitor the AWS and Azure resources with on premises Zabbix Server ?
    Adeel Imtiaz
    There are templates for monitoring those resources. https://www.zabbix.com/integrations?cat=clouds
    You can use them on your on-prem instance... make sure your server or proxy, which ever does polling, can access those webpages, mentioned in scripts... (unfortunately docs do not mention them, you need to dig into the script...
