Dynamic Hostgroup create
  • ithosting
    • May 2016
    1/ I widely use hostgroups and I search a solution to generate dynamically this list ?
    2/ Is it possible to create a hostgroup from another hostgroup ? example :
    hostgroup_toto = vm1, vm2
    hostgroup_titi = vm3, vm4
    hostgroup_all = hostgroup_toto + hostgroup_titi
    with result = vm1, vm2, vm3, vm4
    3/ is it possible to works in CLI command for scripting usage ?
    If you knows the good answer, please send me a reply.
    Have a nice Zabbix Thanks for all
