Referencing proxy in Trigger
  • cameron.mcgregor
    • May 2016
    Is there a way to reference the proxy in the Trigger?
    For example: {HOST.NAME} is not available from {PROXY}
    This would put the actual host name in the alert but it doesn't work for the proxy.
  • dan_cytexone
    • Dec 2008
    • 61
    Have you found a solution to this? I too want to have proxies in the alerts.
    • DmitryL
      • May 2016
      • 278
      Take a look at
      {PROXY.NAME} is supported in:
      * Trigger-based notifications and commands
      * Discovery notifications
      * Auto registration notifications
      * Trigger based internal notifications
      * Item based internal notifications
      * Low-level discovery rule based internal notifications
      Best regards,
      Dmitry
      • dan_cytexone
        • Dec 2008
        • 61
        Unfortunately despite the documentation proxy.name does not work in action notifications.
        The documentation is either wrong or there is a bug in the software
        • dan_cytexone
          • Dec 2008
          • 61
          My bad. My original test I think was missing quotes. This is working.
          Sorry for the false alarm.
          Dan
          • RaulChiarella
            • Apr 2021
            • 59
            Yo. How did u fix this?
            My expression is returning "Proxy {PROXY.NAME} does not exist."
            Item key is zabbix[proxy,{PROXY.NAME},lastaccess] but it returns that it does not exists
            • johndoe2374
              • Aug 2021
              • 80
              I guess you're trying to put this item for your proxy, so you can check for the lastaccess.
              Do you monitor your proxy via itself ("Monitored by proxy - <yourproxy>" on the host configuration page)? And it's required to be so for using "Zabbix proxy health" template for example. I think {PROXY.NAME} resolves into corresponding proxy names only for hosts which are monitored by proxies.
              • RaulChiarella
                • Apr 2021
                • 59
                Yes. I do monitor using proxy. Well. If it is not possible for me to get the name of the proxy in my Zabbix Server in the trigger, how can I reference the host name itself?
                I used `zabbix[proxy,{HOST.NAME},delay]` but the item was saved with the name `{HOST.NAME}` and did not get the name of the host.
                  In item config macros are never expanded...
