I'm trying to follow this manual
https://git.zabbix.com/projects/ZT/r...at=bfa5eb9c8b1
I got stucked at "Configuring Zabbix SNMP gateway", I cannot find the zabbix-snmp-gateway -c ....
It keeps saying "zabbix-snmp-gateway: command not found"
Obvs I should probably have a zabbix-snmp-gateway file but I don't have it.
I only have on /etc/zabbix the following files:
snmp-gateway.json snmp-gateway.json.save web zabbix_agentd.conf zabbix_agentd.d zabbix_java_gateway.conf zabbix_java_gateway_logback.xml zabbix_server.conf
Zabbix was installed from a vm image downloaded from the main page.
Any suggestions?
Any suggestions?
