I am monitoring a device via a HTTP Agent for various alarms , on this HTTP source individual alarms are output in the response body only whilst they are active. This is fine for triggering problems but when the alarm is cleared on the monitored device the line in HTTP response goes away which is where i am having a problem. As there is no entry for the for the triggered alarm in the HTTP response my 'recovery expression' using nodata does not seem to get parsed so my alarm never clears. Is there a trick to work around this ?
Regards
Chris
Regards
Chris
