Zabbix Crash - failover not happening
  • AcesAndrew
    • Sep 2017
    • 9
    Dear community,
    I am running Zabbix using it's native HA mode. Recently, I got a crash on the main node, and while it was stopping the daemon, all processes were killed except the HA Manager Process, therefore, it was still declaring itself as alive, but it was unable to collect any metrics. The other node, didn't trigger switchover, and I got no data for more then 24h until I opened zabbix and noticed that actually it is not running.
    After killing the processes on node2(which was master) it switched to node1 and everything started to work. After restarting node2, everything started just fine, and it is declaring as backup right now. Did anybody has any issues like this before ?
    Below are HA related configs and crash logs
    node1:
    HANodeName=zabbix-01.monitoring.test.net
    NodeAddress=zabbix.monitoring.test.net:10051
    node2:
    HANodeName=zabbix-02.monitoring.test.net
    Crash logs:
    114425:20230221:120537.290 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x38]. Crashing ...
    114425:20230221:120537.290 ====== Fatal information: ======
    114425:20230221:120537.290 Program counter: 0x55e083688de9
    114425:20230221:120537.290 === Registers: ===
    114425:20230221:120537.290 r8      =     7ffd57450248 =      140726067593800 =      140726067593800
    114425:20230221:120537.290 r9      =         63f4b391 =           1676981137 =           1676981137
    114425:20230221:120537.290 r10     =     7ffd57591080 =      140726068908160 =      140726068908160
    114425:20230221:120537.290 r11     =         17381bd4 =            389553108 =            389553108
    114425:20230221:120537.290 r12     =                4 =                    4 =                    4
    114425:20230221:120537.290 r13     =     7ffd5745dfe0 =      140726067650528 =      140726067650528
    114425:20230221:120537.290 r14     =                0 =                    0 =                    0
    114425:20230221:120537.290 r15     =                0 =                    0 =                    0
    114425:20230221:120537.290 rdi     =                0 =                    0 =                    0
    114425:20230221:120537.290 rsi     =     7ffd57450248 =      140726067593800 =      140726067593800
    114425:20230221:120537.290 rbp     =     7ffd57450090 =      140726067593360 =      140726067593360
    114425:20230221:120537.290 rbx     =     7ffd5745cd40 =      140726067645760 =      140726067645760
    114425:20230221:120537.290 rdx     =     7ffd574500d8 =      140726067593432 =      140726067593432
    114425:20230221:120537.290 rax     =                0 =                    0 =                    0
    114425:20230221:120537.290 rcx     =     7ffd574500cc =      140726067593420 =      140726067593420
    114425:20230221:120537.290 rsp     =     7ffd57450060 =      140726067593312 =      140726067593312
    114425:20230221:120537.290 rip     =     55e083688de9 =       94422765702633 =       94422765702633
    114425:20230221:120537.290 efl     =            10206 =                66054 =                66054
    114425:20230221:120537.290 csgsfs  =   2b000000000033 =    12103423998558259 =    12103423998558259
    114425:20230221:120537.290 err     =                4 =                    4 =                    4
    114425:20230221:120537.290 trapno  =                e =                   14 =                   14
    114425:20230221:120537.290 oldmask =             4a06 =                18950 =                18950
    114425:20230221:120537.290 cr2     =               38 =                   56 =                   56
    114425:20230221:120537.290 === Backtrace: ===
    114425:20230221:120537.298 24: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](zbx_backtrace+0x52) [0x55e0836d42b5]
    114425:20230221:120537.298 23: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](zbx_log_fatal_info+0x183) [0x55e0836d45ae]
    114425:20230221:120537.298 22: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x277f60) [0x55e0836d4f60]
    114425:20230221:120537.298 21: /lib/x86_64-linux-gnu/libpthread.so.0(+0x14420) [0x7f0f13202420]
    114425:20230221:120537.298 20: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x22bde9) [0x55e083688de9]
    114425:20230221:120537.298 19: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x22d64a) [0x55e08368a64a]
    114425:20230221:120537.298 18: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x22d93f) [0x55e08368a93f]
    114425:20230221:120537.298 17: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](zbx_vc_get_values+0x179) [0x55e08368b280]
    114425:20230221:120537.298 16: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x231091) [0x55e08368e091]
    114425:20230221:120537.298 15: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x233a9a) [0x55e083690a9a]
    114425:20230221:120537.298 14: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](evaluate_function2+0xbc) [0x55e08369682a]
    114425:20230221:120537.298 13: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x24e3b0) [0x55e0836ab3b0]
    114425:20230221:120537.298 12: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x24ea74) [0x55e0836aba74]
    114425:20230221:120537.298 11: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](evaluate_expressions+0x1e1) [0x55e0836abee0]
    114425:20230221:120537.298 10: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x1e9e29) [0x55e083646e29]
    114425:20230221:120537.298 9: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x1ee262) [0x55e08364b262]
    114425:20230221:120537.298 8: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](zbx_sync_history_cache+0x8b) [0x55e08364bdb0]
    114425:20230221:120537.298 7: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](dbsyncer_thread+0x236) [0x55e0834d9231]
    114425:20230221:120537.298 6: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](zbx_thread_start+0x3b) [0x55e0836e59c7]
    114425:20230221:120537.298 5: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](+0x689e7) [0x55e0834c59e7]
    114425:20230221:120537.298 4: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](MAIN_ZABBIX_ENTRY+0xb6f) [0x55e0834c6cb4]
    114425:20230221:120537.298 3: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](daemon_start+0x3ca) [0x55e0836d3dd8]
    114425:20230221:120537.298 2: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](main+0x34d) [0x55e0834c4ee2]
    114425:20230221:120537.298 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f0f12419083]
    114425:20230221:120537.298 0: /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000041 sec, syncing history](_start+0x2e) [0x55e0834c3b4e]
    114425:20230221:120537.298 === Memory map: ===
    114425:20230221:120537.298 55e08345d000-55e0834c0000 r--p 00000000 103:01 68077                     /usr/sbin/zabbix_server
    114425:20230221:120537.298 55e0834c0000-55e083801000 r-xp 00063000 103:01 68077                     /usr/sbin/zabbix_server
    114425:20230221:120537.298 55e083801000-55e083920000 r--p 003a4000 103:01 68077                     /usr/sbin/zabbix_server
    114425:20230221:120537.298 55e083921000-55e0839ea000 r--p 004c3000 103:01 68077                     /usr/sbin/zabbix_server
    114425:20230221:120537.298 55e0839ea000-55e0839fa000 rw-p 0058c000 103:01 68077                     /usr/sbin/zabbix_server
    114425:20230221:120537.298 55e0839fa000-55e083a09000 rw-p 00000000 00:00 0
    114425:20230221:120537.298 55e085130000-55e08517e000 rw-p 00000000 00:00 0                          [heap]
    114425:20230221:120537.298 55e08517e000-55e0851c2000 rw-p 00000000 00:00 0                          [heap]
    114425:20230221:120537.298 55e0851c2000-55e0887e2000 rw-p 00000000 00:00 0                          [heap]
    114425:20230221:120537.298 7f0e328f2000-7f0e32cf2000 rw-s 00000000 00:01 11                         /SYSV00000000 (deleted)
    114425:20230221:120537.298 7f0e32cf2000-7f0e334f2000 rw-s 00000000 00:01 10                         /SYSV00000000 (deleted)
    114425:20230221:120537.298 7f0e334f2000-7f0f0e0f2000 rw-s 00000000 00:01 8                          /SYSV00000000 (deleted)
    114425:20230221:120537.298 7f0f0e0f2000-7f0f0e4f2000 rw-s 00000000 00:01 7                          /SYSV00000000 (deleted)
    114425:20230221:120537.298 7f0f0e4f2000-7f0f0e8f2000 rw-s 00000000 00:01 6                          /SYSV00000000 (deleted)
    114425:20230221:120537.298 7f0f0e8f2000-7f0f0f8f2000 rw-s 00000000 00:01 5                          /SYSV00000000 (deleted)
    114425:20230221:120537.298 7f0f0f8f2000-7f0f0f8f3000 r--p 00000000 103:01 3478                      /usr/lib/x86_64-linux-gnu/libnss_dns-2.31.so
    114425:20230221:120537.298 7f0f0f8f3000-7f0f0f8f7000 r-xp 00001000 103:01 3478                      /usr/lib/x86_64-linux-gnu/libnss_dns-2.31.so
    114425:20230221:120537.298 7f0f0f8f7000-7f0f0f8f8000 r--p 00005000 103:01 3478                      /usr/lib/x86_64-linux-gnu/libnss_dns-2.31.so
    114425:20230221:120537.298 7f0f0f8f8000-7f0f0f8f9000 r--p 00005000 103:01 3478                      /usr/lib/x86_64-linux-gnu/libnss_dns-2.31.so
    114425:20230221:120537.298 7f0f0f8f9000-7f0f0f8fa000 rw-p 00006000 103:01 3478                      /usr/lib/x86_64-linux-gnu/libnss_dns-2.31.so
    114425:20230221:120537.298 7f0f0f8fa000-7f0f0f900000 r--p 00000000 103:01 4552                      /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    114425:20230221:120537.298 7f0f0f900000-7f0f0f926000 r-xp 00006000 103:01 4552                      /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    114425:20230221:120537.298 7f0f0f926000-7f0f0f932000 r--p 0002c000 103:01 4552                      /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    114425:20230221:120537.298 7f0f0f932000-7f0f0f935000 r--p 00037000 103:01 4552                      /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    114425:20230221:120537.298 7f0f0f935000-7f0f0f936000 rw-p 0003a000 103:01 4552                      /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    114425:20230221:120537.298 7f0f0f936000-7f0f0f939000 r--p 00000000 103:01 3479                      /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    114425:20230221:120537.298 7f0f0f939000-7f0f0f940000 r-xp 00003000 103:01 3479                      /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    114425:20230221:120537.298 7f0f0f940000-7f0f0f942000 r--p 0000a000 103:01 3479                      /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    114425:20230221:120537.298 7f0f0f942000-7f0f0f943000 r--p 0000b000 103:01 3479                      /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    114425:20230221:120537.298 7f0f0f943000-7f0f0f944000 rw-p 0000c000 103:01 3479                      /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    114425:20230221:120537.298 7f0f0f944000-7f0f0f953000 rw-p 00000000 00:00 0
    114425:20230221:120537.298 7f0f0f953000-7f0f0f955000 r--p 00000000 103:01 3828                      /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    114425:20230221:120537.298 7f0f0f955000-7f0f0f95b000 r-xp 00002000 103:01 3828                      /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    114425:20230221:120537.298 7f0f0f95b000-7f0f0f95c000 r--p 00008000 103:01 3828                      /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    114425:20230221:120537.298 7f0f0f95c000-7f0f0f95d000 ---p 00009000 103:01 3828                      /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    114425:20230221:120537.298 7f0f0f95d000-7f0f0f95e000 r--p 00009000 103:01 3828                      /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    114425:20230221:120537.298 7f0f0f95e000-7f0f0f95f000 rw-p 0000a000 103:01 3828                      /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    114425:20230221:120537.298 7f0f0f95f000-7f0f0f961000 r--p 00000000 103:01 3472                      /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    114425:20230221:120537.298 7f0f0f961000-7f0f0f976000 r-xp 00002000 103:01 3472                      /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    114425:20230221:120537.298 7f0f0f976000-7f0f0f990000 r--p 00017000 103:01 3472                      /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    114425:20230221:120537.298 7f0f0f990000-7f0f0f991000 r--p 00030000 103:01 3472                      /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    114425:20230221:120537.298 7f0f0f991000-7f0f0f992000 rw-p 00031000 103:01 3472                      /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    114425:20230221:120537.298 7f0f0f992000-7f0f0f99a000 rw-p 00000000 00:00 0
    114425:20230221:120537.298 7f0f0f99a000-7f0f0f9a8000 r--p 00000000 103:01 6227                      /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    114425:20230221:120537.298 7f0f0f9a8000-7f0f0fa88000 r-xp 0000e000 103:01 6227                      /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    114425:20230221:120537.298 7f0f0fa88000-7f0f0fabc000 r--p 000ee000 103:01 6227                      /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    114425:20230221:120537.298 7f0f0fabc000-7f0f0fabd000 ---p 00122000 103:01 6227                      /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    114425:20230221:120537.298 7f0f0fabd000-7f0f0fac0000 r--p 00122000 103:01 6227                      /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    114425:20230221:120537.298 7f0f0fac0000-7f0f0fac3000 rw-p 00125000 103:01 6227                      /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    114425:20230221:120537.298 7f0f0fac3000-7f0f0fac5000 rw-p 00000000 00:00 0
    114425:20230221:120537.299 7f0f0fb4f000-7f0f0fb51000 r--p 00000000 103:01 5296                      /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    114425:20230221:120537.299 7f0f0fb51000-7f0f0fb53000 r-xp 00002000 103:01 5296                      /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    114425:20230221:120537.299 7f0f0fb53000-7f0f0fb54000 r--p 00004000 103:01 5296                      /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    114425:20230221:120537.299 7f0f0fb54000-7f0f0fb55000 r--p 00004000 103:01 5296                      /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    114425:20230221:120537.299 7f0f0fb55000-7f0f0fb56000 rw-p 00005000 103:01 5296                      /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    114425:20230221:120537.299 7f0f0fb56000-7f0f0fb57000 r--p 00000000 103:01 5426                      /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    114425:20230221:120537.299 7f0f0fb57000-7f0f0fb58000 r-xp 00001000 103:01 5426                      /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    114425:20230221:120537.299 7f0f0fb58000-7f0f0fb77000 r--p 00002000 103:01 5426                      /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    114425:20230221:120537.299 7f0f0fb77000-7f0f0fb78000 r--p 00020000 103:01 5426                      /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    114425:20230221:120537.299 7f0f0fb78000-7f0f0fb79000 rw-p 00021000 103:01 5426                      /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    114425:20230221:120537.299 7f0f0fb79000-7f0f0fb7b000 rw-p 00000000 00:00 0
    114425:20230221:120537.299 7f0f0fb7b000-7f0f0fb85000 r--p 00000000 103:01 12359                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    114425:20230221:120537.299 7f0f0fb85000-7f0f0fbe5000 r-xp 0000a000 103:01 12359                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    114425:20230221:120537.299 7f0f0fbe5000-7f0f0fbfc000 r--p 0006a000 103:01 12359                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    114425:20230221:120537.299 7f0f0fbfc000-7f0f0fbfd000 ---p 00081000 103:01 12359                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    114425:20230221:120537.299 7f0f0fbfd000-7f0f0fbfe000 r--p 00081000 103:01 12359                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    114425:20230221:120537.299 7f0f0fbfe000-7f0f0fbff000 rw-p 00082000 103:01 12359                     /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    114425:20230221:120537.299 7f0f0fbff000-7f0f0fc06000 r--p 00000000 103:01 3499                      /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    114425:20230221:120537.299 7f0f0fc06000-7f0f0fc16000 r-xp 00007000 103:01 3499                      /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    114425:20230221:120537.299 7f0f0fc16000-7f0f0fc34000 r--p 00017000 103:01 3499                      /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    114425:20230221:120537.299 7f0f0fc34000-7f0f0fc35000 r--p 00034000 103:01 3499                      /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    114425:20230221:120537.299 7f0f0fc35000-7f0f0fc36000 rw-p 00035000 103:01 3499                      /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    114425:20230221:120537.299 7f0f0fc36000-7f0f0fc3f000 r--p 00000000 103:01 4598                      /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    114425:20230221:120537.299 7f0f0fc3f000-7f0f0fc5d000 r-xp 00009000 103:01 4598                      /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    114425:20230221:120537.299 7f0f0fc5d000-7f0f0fc6d000 r--p 00027000 103:01 4598                      /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    114425:20230221:120537.299 7f0f0fc6d000-7f0f0fc6f000 r--p 00036000 103:01 4598                      /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    114425:20230221:120537.299 7f0f0fc6f000-7f0f0fc70000 rw-p 00038000 103:01 4598                      /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    114425:20230221:120537.299 7f0f0fc70000-7f0f0fc73000 r--p 00000000 103:01 4569                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    114425:20230221:120537.299 7f0f0fc73000-7f0f0fc7f000 r-xp 00003000 103:01 4569                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    114425:20230221:120537.299 7f0f0fc7f000-7f0f0fc83000 r--p 0000f000 103:01 4569                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    114425:20230221:120537.299 7f0f0fc83000-7f0f0fc84000 ---p 00013000 103:01 4569                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    114425:20230221:120537.299 7f0f0fc84000-7f0f0fc85000 r--p 00013000 103:01 4569                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    114425:20230221:120537.299 7f0f0fc85000-7f0f0fc86000 rw-p 00014000 103:01 4569                      /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    114425:20230221:120537.299 7f0f0fc86000-7f0f0fc96000 r--p 00000000 103:01 4571                      /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    114425:20230221:120537.299 7f0f0fc96000-7f0f0fccc000 r-xp 00010000 103:01 4571                      /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    114425:20230221:120537.299 7f0f0fccc000-7f0f0fe03000 r--p 00046000 103:01 4571                      /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    114425:20230221:120537.299 7f0f0fe03000-7f0f0fe04000 ---p 0017d000 103:01 4571                      /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    114425:20230221:120537.299 7f0f0fe04000-7f0f0fe07000 r--p 0017d000 103:01 4571                      /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    114425:20230221:120537.299 7f0f0fe07000-7f0f0fe08000 rw-p 00180000 103:01 4571                      /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    114425:20230221:120537.299 7f0f0fe08000-7f0f0fe33000 r--p 00000000 103:01 3776                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    114425:20230221:120537.299 7f0f0fe33000-7f0f0fecd000 r-xp 0002b000 103:01 3776                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    114425:20230221:120537.299 7f0f0fecd000-7f0f0ff29000 r--p 000c5000 103:01 3776                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    114425:20230221:120537.299 7f0f0ff29000-7f0f0ff34000 r--p 00120000 103:01 3776                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    114425:20230221:120537.299 7f0f0ff34000-7f0f0ff3e000 rw-p 0012b000 103:01 3776                      /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    114425:20230221:120537.299 7f0f0ff3e000-7f0f0ff40000 rw-p 00000000 00:00 0
    114425:20230221:120537.299 7f0f100c9000-7f0f100ca000 rw-p 00000000 00:00 0
    114425:20230221:120537.299 7f0f100d9000-7f0f100e0000 r-xp 00003000 103:01 9871                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    114425:20230221:120537.299 7f0f100e0000-7f0f100e3000 r--p 0000a000 103:01 9871                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    114425:20230221:120537.299 7f0f100e3000-7f0f100e4000 r--p 0000c000 103:01 9871                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    114425:20230221:120537.299 7f0f100e4000-7f0f100e5000 rw-p 0000d000 103:01 9871                      /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    114425:20230221:120537.299 7f0f100e5000-7f0f100e7000 rw-p 00000000 00:00 0
    114425:20230221:120537.299 7f0f100e7000-7f0f100e9000 r--p 00000000 103:01 3841                      /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    114425:20230221:120537.299 7f0f100e9000-7f0f100eb000 r-xp 00002000 103:01 3841                      /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    114425:20230221:120537.299 7f0f100eb000-7f0f100ec000 r--p 00004000 103:01 3841                      /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    114425:20230221:120537.299 7f0f100ec000-7f0f100ed000 r--p 00004000 103:01 3841                      /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    114425:20230221:120537.299 7f0f100ed000-7f0f100ee000 rw-p 00005000 103:01 3841                      /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    114425:20230221:120537.299 7f0f100ee000-7f0f100f2000 r--p 00000000 103:01 12579                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    114425:20230221:120537.299 7f0f100f2000-7f0f1010e000 r-xp 00004000 103:01 12579                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    114425:20230221:120537.299 7f0f1010e000-7f0f1011b000 r--p 00020000 103:01 12579                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    114425:20230221:120537.299 7f0f1011b000-7f0f1011c000 ---p 0002d000 103:01 12579                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    114425:20230221:120537.299 7f0f1011c000-7f0f1011d000 r--p 0002d000 103:01 12579                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    114425:20230221:120537.299 7f0f1011d000-7f0f1011e000 rw-p 0002e000 103:01 12579                     /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    114425:20230221:120537.299 7f0f1011e000-7f0f1011f000 rw-p 00000000 00:00 0
    114425:20230221:120537.299 7f0f1011f000-7f0f10141000 r--p 00000000 103:01 12487                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    114425:20230221:120537.299 7f0f10141000-7f0f101a2000 r-xp 00022000 103:01 12487                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    114425:20230221:120537.299 7f0f101a2000-7f0f101eb000 r--p 00083000 103:01 12487                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    114425:20230221:120537.299 7f0f101eb000-7f0f101ec000 ---p 000cc000 103:01 12487                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    114425:20230221:120537.299 7f0f101ec000-7f0f101fa000 r--p 000cc000 103:01 12487                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    114425:20230221:120537.299 7f0f101fa000-7f0f101fc000 rw-p 000da000 103:01 12487                     /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    114425:20230221:120537.299 7f0f101fc000-7f0f101fd000 r--p 00000000 103:01 4631                      /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    114425:20230221:120537.299 7f0f101fd000-7f0f101fe000 r-xp 00001000 103:01 4631                      /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    114425:20230221:120537.299 7f0f101fe000-7f0f11cbb000 r--p 00002000 103:01 4631                      /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    114425:20230221:120537.299 7f0f11cbb000-7f0f11cbc000 r--p 01abe000 103:01 4631                      /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    114425:20230221:120537.299 7f0f11cbc000-7f0f11cbd000 rw-p 01abf000 103:01 4631                      /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    114425:20230221:120537.299 7f0f11cbd000-7f0f11cbe000 r--p 00000000 103:01 5427                      /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    114425:20230221:120537.299 7f0f11cbe000-7f0f11cc6000 r-xp 00001000 103:01 5427                      /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    114425:20230221:120537.299 7f0f11cc6000-7f0f11cc9000 r--p 00009000 103:01 5427                      /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    114425:20230221:120537.300 7f0f11cc9000-7f0f11cca000 r--p 0000b000 103:01 5427                      /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    114425:20230221:120537.300 7f0f11cca000-7f0f11ccb000 rw-p 0000c000 103:01 5427                      /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    114425:20230221:120537.300 7f0f11ccb000-7f0f11ccd000 rw-p 00000000 00:00 0
    114425:20230221:120537.300 7f0f11ccd000-7f0f11ccf000 r--p 00000000 103:01 5365                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    114425:20230221:120537.300 7f0f11ccf000-7f0f11cd1000 r-xp 00002000 103:01 5365                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    114425:20230221:120537.300 7f0f11cd1000-7f0f11cde000 r--p 00004000 103:01 5365                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    114425:20230221:120537.300 7f0f11cde000-7f0f11cdf000 r--p 00010000 103:01 5365                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    114425:20230221:120537.300 7f0f11cdf000-7f0f11ce0000 rw-p 00011000 103:01 5365                      /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    114425:20230221:120537.300 7f0f11ce0000-7f0f11ce5000 r--p 00000000 103:01 5495                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
    114425:20230221:120537.300 7f0f11ce5000-7f0f11cf6000 r-xp 00005000 103:01 5495                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
    114425:20230221:120537.300 7f0f11cf6000-7f0f11cfd000 r--p 00016000 103:01 5495                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
    114425:20230221:120537.300 7f0f11cfd000-7f0f11cfe000 ---p 0001d000 103:01 5495                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
    114425:20230221:120537.300 7f0f11cfe000-7f0f11cff000 r--p 0001d000 103:01 5495                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
    114425:20230221:120537.300 7f0f11cff000-7f0f11d00000 rw-p 0001e000 103:01 5495                      /usr/lib/x86_64-linux-gnu/librtmp.so.1
    114425:20230221:120537.300 7f0f11d00000-7f0f11d02000 r--p 00000000 103:01 4539                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    114425:20230221:120537.300 7f0f11d02000-7f0f11d07000 r-xp 00002000 103:01 4539                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    114425:20230221:120537.300 7f0f11d07000-7f0f11d1e000 r--p 00007000 103:01 4539                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    114425:20230221:120537.300 7f0f11d1e000-7f0f11d1f000 ---p 0001e000 103:01 4539                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    114425:20230221:120537.300 7f0f11d1f000-7f0f11d20000 r--p 0001e000 103:01 4539                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    114425:20230221:120537.300 7f0f11d20000-7f0f11d21000 rw-p 0001f000 103:01 4539                      /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    114425:20230221:120537.300 7f0f11d21000-7f0f11d26000 r--p 00000000 103:01 5493                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    114425:20230221:120537.300 7f0f11d26000-7f0f11d39000 r-xp 00005000 103:01 5493                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    114425:20230221:120537.300 7f0f11d39000-7f0f11d46000 r--p 00018000 103:01 5493                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    114425:20230221:120537.300 7f0f11d46000-7f0f11d49000 r--p 00024000 103:01 5493                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    114425:20230221:120537.300 7f0f11d49000-7f0f11d4a000 rw-p 00027000 103:01 5493                      /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    114425:20230221:120537.300 7f0f11d4a000-7f0f11d79000 r--p 00000000 103:01 13571                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    114425:20230221:120537.300 7f0f11d79000-7f0f11e9b000 r-xp 0002f000 103:01 13571                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    114425:20230221:120537.300 7f0f11e9b000-7f0f11f0c000 r--p 00151000 103:01 13571                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    114425:20230221:120537.300 7f0f11f0c000-7f0f11f0d000 ---p 001c2000 103:01 13571                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    114425:20230221:120537.300 7f0f11f0d000-7f0f11f1c000 r--p 001c2000 103:01 13571                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    114425:20230221:120537.300 7f0f11f1c000-7f0f11f1e000 rw-p 001d1000 103:01 13571                     /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    114425:20230221:120537.300 7f0f11f1e000-7f0f11f20000 rw-p 00000000 00:00 0
    114425:20230221:120537.300 7f0f11f67000-7f0f11f6a000 r--p 00000000 103:01 5486                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    114425:20230221:120537.300 7f0f11f6a000-7f0f11f7c000 r-xp 00003000 103:01 5486                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    114425:20230221:120537.300 7f0f11f7c000-7f0f11f82000 r--p 00015000 103:01 5486                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    114425:20230221:120537.300 7f0f11f82000-7f0f11f83000 r--p 0001a000 103:01 5486                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    114425:20230221:120537.300 7f0f11f83000-7f0f11f84000 rw-p 0001b000 103:01 5486                      /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    114425:20230221:120537.300 7f0f11f84000-7f0f11f86000 r--p 00000000 103:01 68007                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    114425:20230221:120537.300 7f0f11f86000-7f0f11f8b000 r-xp 00002000 103:01 68007                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    114425:20230221:120537.300 7f0f11f8b000-7f0f11f8d000 r--p 00007000 103:01 68007                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    114425:20230221:120537.300 7f0f11f8d000-7f0f11f8e000 r--p 00008000 103:01 68007                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    114425:20230221:120537.300 7f0f11f8e000-7f0f11f8f000 rw-p 00009000 103:01 68007                     /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    114425:20230221:120537.300 7f0f11f8f000-7f0f11f9a000 r--p 00000000 103:01 12331                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    114425:20230221:120537.300 7f0f11f9a000-7f0f11fcc000 r-xp 0000b000 103:01 12331                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    114425:20230221:120537.300 7f0f11fcc000-7f0f11fd8000 r--p 0003d000 103:01 12331                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    114425:20230221:120537.300 7f0f11fd8000-7f0f11fda000 r--p 00048000 103:01 12331                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    114425:20230221:120537.300 7f0f11fda000-7f0f11fdc000 rw-p 0004a000 103:01 12331                     /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    114425:20230221:120537.300 7f0f11fdc000-7f0f11fde000 r--p 00000000 103:01 5649                      /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    114425:20230221:120537.300 7f0f11fde000-7f0f11fe3000 r-xp 00002000 103:01 5649                      /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    114425:20230221:120537.300 7f0f11fe3000-7f0f11fe5000 r--p 00007000 103:01 5649                      /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    114425:20230221:120537.300 7f0f11fe5000-7f0f11fe6000 r--p 00008000 103:01 5649                      /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    114425:20230221:120537.300 7f0f11fe6000-7f0f11fe7000 rw-p 00009000 103:01 5649                      /usr/lib/x86_64-linux-gnu/libltdl.so.7.3.1
    114425:20230221:120537.300 7f0f11fe7000-7f0f11fea000 r--p 00000000 103:01 3764                      /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    114425:20230221:120537.300 7f0f11fea000-7f0f12002000 r-xp 00003000 103:01 3764                      /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    114425:20230221:120537.300 7f0f12002000-7f0f1200d000 r--p 0001b000 103:01 3764                      /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    114425:20230221:120537.300 7f0f1200d000-7f0f1200e000 ---p 00026000 103:01 3764                      /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    114425:20230221:120537.300 7f0f1200e000-7f0f1200f000 r--p 00026000 103:01 3764                      /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    114425:20230221:120537.300 7f0f1200f000-7f0f12010000 rw-p 00027000 103:01 3764                      /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    114425:20230221:120537.300 7f0f12010000-7f0f12012000 rw-p 00000000 00:00 0
    114425:20230221:120537.300 7f0f12012000-7f0f12077000 r--p 00000000 103:01 4636                      /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    114425:20230221:120537.300 7f0f12077000-7f0f1215c000 r-xp 00065000 103:01 4636                      /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    114425:20230221:120537.300 7f0f1215c000-7f0f121e2000 r--p 0014a000 103:01 4636                      /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    114425:20230221:120537.300 7f0f121e2000-7f0f121e3000 ---p 001d0000 103:01 4636                      /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    114425:20230221:120537.300 7f0f121e3000-7f0f121f5000 r--p 001d0000 103:01 4636                      /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    114425:20230221:120537.300 7f0f121f5000-7f0f121f6000 rw-p 001e2000 103:01 4636                      /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    114425:20230221:120537.300 7f0f121f6000-7f0f121f8000 rw-p 00000000 00:00 0
    114425:20230221:120537.300 7f0f121f8000-7f0f121fb000 r--p 00000000 103:01 3454                      /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    114425:20230221:120537.300 7f0f121fb000-7f0f1220d000 r-xp 00003000 103:01 3454                      /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    114425:20230221:120537.300 7f0f1220d000-7f0f12211000 r--p 00015000 103:01 3454                      /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    114425:20230221:120537.300 7f0f12211000-7f0f12212000 r--p 00018000 103:01 3454                      /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    114425:20230221:120537.300 7f0f12212000-7f0f12213000 rw-p 00019000 103:01 3454                      /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    114425:20230221:120537.300 7f0f12213000-7f0f122a9000 r--p 00000000 103:01 3455                      /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    114425:20230221:120537.300 7f0f122a9000-7f0f1239a000 r-xp 00096000 103:01 3455                      /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    114425:20230221:120537.300 7f0f1239a000-7f0f123e3000 r--p 00187000 103:01 3455                      /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    114425:20230221:120537.300 7f0f123e3000-7f0f123e4000 ---p 001d0000 103:01 3455                      /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    114425:20230221:120537.300 7f0f123e4000-7f0f123ef000 r--p 001d0000 103:01 3455                      /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    114425:20230221:120537.300 7f0f123ef000-7f0f123f2000 rw-p 001db000 103:01 3455                      /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    114425:20230221:120537.300 7f0f123f2000-7f0f123f5000 rw-p 00000000 00:00 0
    114425:20230221:120537.300 7f0f123f5000-7f0f12417000 r--p 00000000 103:01 3463                      /usr/lib/x86_64-linux-gnu/libc-2.31.so
    114425:20230221:120537.301 7f0f12417000-7f0f1258f000 r-xp 00022000 103:01 3463                      /usr/lib/x86_64-linux-gnu/libc-2.31.so
    114425:20230221:120537.301 7f0f1258f000-7f0f125dd000 r--p 0019a000 103:01 3463                      /usr/lib/x86_64-linux-gnu/libc-2.31.so
    114425:20230221:120537.301 7f0f125dd000-7f0f125e1000 r--p 001e7000 103:01 3463                      /usr/lib/x86_64-linux-gnu/libc-2.31.so
    114425:20230221:120537.301 7f0f125e1000-7f0f125e3000 rw-p 001eb000 103:01 3463                      /usr/lib/x86_64-linux-gnu/libc-2.31.so
    114425:20230221:120537.301 7f0f125e3000-7f0f125e7000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f125e7000-7f0f125e9000 r--p 00000000 103:01 6883                      /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    114425:20230221:120537.301 7f0f125e9000-7f0f1264e000 r-xp 00002000 103:01 6883                      /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    114425:20230221:120537.301 7f0f1264e000-7f0f12676000 r--p 00067000 103:01 6883                      /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    114425:20230221:120537.301 7f0f12676000-7f0f12677000 r--p 0008e000 103:01 6883                      /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    114425:20230221:120537.301 7f0f12677000-7f0f12678000 rw-p 0008f000 103:01 6883                      /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    114425:20230221:120537.301 7f0f12678000-7f0f1267a000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f1267a000-7f0f12687000 r--p 00000000 103:01 6848                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    114425:20230221:120537.301 7f0f12687000-7f0f126eb000 r-xp 0000d000 103:01 6848                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    114425:20230221:120537.301 7f0f126eb000-7f0f12706000 r--p 00071000 103:01 6848                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    114425:20230221:120537.301 7f0f12706000-7f0f12707000 ---p 0008c000 103:01 6848                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    114425:20230221:120537.301 7f0f12707000-7f0f1270b000 r--p 0008c000 103:01 6848                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    114425:20230221:120537.301 7f0f1270b000-7f0f1270c000 rw-p 00090000 103:01 6848                      /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    114425:20230221:120537.301 7f0f1270c000-7f0f1270f000 r--p 00000000 103:01 5488                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1270f000-7f0f12717000 r-xp 00003000 103:01 5488                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f12717000-7f0f1271a000 r--p 0000b000 103:01 5488                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1271a000-7f0f1271b000 ---p 0000e000 103:01 5488                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1271b000-7f0f1271c000 r--p 0000e000 103:01 5488                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1271c000-7f0f1271d000 rw-p 0000f000 103:01 5488                      /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1271d000-7f0f1272a000 r--p 00000000 103:01 5489                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1272a000-7f0f1275e000 r-xp 0000d000 103:01 5489                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1275e000-7f0f1276d000 r--p 00041000 103:01 5489                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1276d000-7f0f1276e000 ---p 00050000 103:01 5489                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f1276e000-7f0f12770000 r--p 00050000 103:01 5489                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f12770000-7f0f12771000 rw-p 00052000 103:01 5489                      /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    114425:20230221:120537.301 7f0f12771000-7f0f12773000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f12773000-7f0f1277f000 r--p 00000000 103:01 5414                      /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    114425:20230221:120537.301 7f0f1277f000-7f0f127b3000 r-xp 0000c000 103:01 5414                      /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    114425:20230221:120537.301 7f0f127b3000-7f0f127c7000 r--p 00040000 103:01 5414                      /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    114425:20230221:120537.301 7f0f127c7000-7f0f127c8000 r--p 00053000 103:01 5414                      /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    114425:20230221:120537.301 7f0f127c8000-7f0f127c9000 rw-p 00054000 103:01 5414                      /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    114425:20230221:120537.301 7f0f127c9000-7f0f127cb000 r--p 00000000 103:01 68004                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    114425:20230221:120537.301 7f0f127cb000-7f0f127cf000 r-xp 00002000 103:01 68004                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    114425:20230221:120537.301 7f0f127cf000-7f0f127d0000 r--p 00006000 103:01 68004                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    114425:20230221:120537.301 7f0f127d0000-7f0f127d1000 ---p 00007000 103:01 68004                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    114425:20230221:120537.301 7f0f127d1000-7f0f127d2000 r--p 00007000 103:01 68004                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    114425:20230221:120537.301 7f0f127d2000-7f0f127d3000 rw-p 00008000 103:01 68004                     /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    114425:20230221:120537.301 7f0f127d3000-7f0f12801000 r--p 00000000 103:01 68002                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    114425:20230221:120537.301 7f0f12801000-7f0f1287e000 r-xp 0002e000 103:01 68002                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    114425:20230221:120537.301 7f0f1287e000-7f0f128bc000 r--p 000ab000 103:01 68002                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    114425:20230221:120537.301 7f0f128bc000-7f0f128d3000 r--p 000e8000 103:01 68002                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    114425:20230221:120537.301 7f0f128d3000-7f0f128d8000 rw-p 000ff000 103:01 68002                     /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    114425:20230221:120537.301 7f0f128d8000-7f0f128de000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f128de000-7f0f128eb000 r--p 00000000 103:01 5496                      /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    114425:20230221:120537.301 7f0f128eb000-7f0f1292c000 r-xp 0000d000 103:01 5496                      /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    114425:20230221:120537.301 7f0f1292c000-7f0f12947000 r--p 0004e000 103:01 5496                      /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    114425:20230221:120537.301 7f0f12947000-7f0f12948000 ---p 00069000 103:01 5496                      /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    114425:20230221:120537.301 7f0f12948000-7f0f1294a000 r--p 00069000 103:01 5496                      /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    114425:20230221:120537.301 7f0f1294a000-7f0f1294c000 rw-p 0006b000 103:01 5496                      /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    114425:20230221:120537.301 7f0f1294c000-7f0f12961000 r--p 00000000 103:01 14472                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    114425:20230221:120537.301 7f0f12961000-7f0f129db000 r-xp 00015000 103:01 14472                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    114425:20230221:120537.301 7f0f129db000-7f0f12a00000 r--p 0008f000 103:01 14472                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    114425:20230221:120537.301 7f0f12a00000-7f0f12a01000 ---p 000b4000 103:01 14472                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    114425:20230221:120537.301 7f0f12a01000-7f0f12a02000 r--p 000b4000 103:01 14472                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    114425:20230221:120537.301 7f0f12a02000-7f0f12a05000 rw-p 000b5000 103:01 14472                     /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    114425:20230221:120537.301 7f0f12a05000-7f0f12aca000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f12aca000-7f0f12ad1000 r--p 00000000 103:01 67990                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    114425:20230221:120537.301 7f0f12ad1000-7f0f12b1f000 r-xp 00007000 103:01 67990                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    114425:20230221:120537.301 7f0f12b1f000-7f0f12b30000 r--p 00055000 103:01 67990                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    114425:20230221:120537.301 7f0f12b30000-7f0f12b31000 r--p 00065000 103:01 67990                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    114425:20230221:120537.301 7f0f12b31000-7f0f12b38000 rw-p 00066000 103:01 67990                     /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    114425:20230221:120537.301 7f0f12b38000-7f0f12b3c000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f12b3c000-7f0f12b69000 r--p 00000000 103:01 6051                      /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    114425:20230221:120537.301 7f0f12b69000-7f0f12c93000 r-xp 0002d000 103:01 6051                      /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    114425:20230221:120537.301 7f0f12c93000-7f0f12cea000 r--p 00157000 103:01 6051                      /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    114425:20230221:120537.301 7f0f12cea000-7f0f12cf3000 r--p 001ad000 103:01 6051                      /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    114425:20230221:120537.301 7f0f12cf3000-7f0f12cf4000 rw-p 001b6000 103:01 6051                      /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    114425:20230221:120537.301 7f0f12cf4000-7f0f12cf6000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f12cf6000-7f0f12cfa000 r--p 00000000 103:01 3489                      /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    114425:20230221:120537.301 7f0f12cfa000-7f0f12d0a000 r-xp 00004000 103:01 3489                      /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    114425:20230221:120537.301 7f0f12d0a000-7f0f12d0e000 r--p 00014000 103:01 3489                      /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    114425:20230221:120537.301 7f0f12d0e000-7f0f12d0f000 r--p 00017000 103:01 3489                      /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    114425:20230221:120537.301 7f0f12d0f000-7f0f12d10000 rw-p 00018000 103:01 3489                      /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    114425:20230221:120537.301 7f0f12d10000-7f0f12d12000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f12d12000-7f0f12d13000 r--p 00000000 103:01 3464                      /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    114425:20230221:120537.301 7f0f12d13000-7f0f12d15000 r-xp 00001000 103:01 3464                      /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    114425:20230221:120537.301 7f0f12d15000-7f0f12d16000 r--p 00003000 103:01 3464                      /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    114425:20230221:120537.301 7f0f12d16000-7f0f12d17000 r--p 00003000 103:01 3464                      /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    114425:20230221:120537.301 7f0f12d17000-7f0f12d18000 rw-p 00004000 103:01 3464                      /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    114425:20230221:120537.301 7f0f12d18000-7f0f12d1a000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f13090000-7f0f13137000 r-xp 0000d000 103:01 3465                      /usr/lib/x86_64-linux-gnu/libm-2.31.so
    114425:20230221:120537.301 7f0f13137000-7f0f131d0000 r--p 000b4000 103:01 3465                      /usr/lib/x86_64-linux-gnu/libm-2.31.so
    114425:20230221:120537.301 7f0f131d0000-7f0f131d1000 r--p 0014c000 103:01 3465                      /usr/lib/x86_64-linux-gnu/libm-2.31.so
    114425:20230221:120537.301 7f0f131d1000-7f0f131d2000 rw-p 0014d000 103:01 3465                      /usr/lib/x86_64-linux-gnu/libm-2.31.so
    114425:20230221:120537.301 7f0f131d2000-7f0f131d4000 r--p 00000000 103:01 12594                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    114425:20230221:120537.301 7f0f131d4000-7f0f131e5000 r-xp 00002000 103:01 12594                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    114425:20230221:120537.301 7f0f131e5000-7f0f131eb000 r--p 00013000 103:01 12594                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    114425:20230221:120537.301 7f0f131eb000-7f0f131ec000 ---p 00019000 103:01 12594                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    114425:20230221:120537.301 7f0f131ec000-7f0f131ed000 r--p 00019000 103:01 12594                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    114425:20230221:120537.301 7f0f131ed000-7f0f131ee000 rw-p 0001a000 103:01 12594                     /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    114425:20230221:120537.301 7f0f131ee000-7f0f131f4000 r--p 00000000 103:01 3488                      /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    114425:20230221:120537.301 7f0f131f4000-7f0f13205000 r-xp 00006000 103:01 3488                      /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    114425:20230221:120537.301 7f0f13205000-7f0f1320b000 r--p 00017000 103:01 3488                      /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    114425:20230221:120537.301 7f0f1320b000-7f0f1320c000 r--p 0001c000 103:01 3488                      /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    114425:20230221:120537.301 7f0f1320c000-7f0f1320d000 rw-p 0001d000 103:01 3488                      /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    114425:20230221:120537.301 7f0f1320d000-7f0f13211000 rw-p 00000000 00:00 0
    114425:20230221:120537.301 7f0f13211000-7f0f1323a000 r--p 00000000 103:01 5330                      /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.32
    114425:20230221:120537.301 7f0f1323a000-7f0f1336b000 r-xp 00029000 103:01 5330                      /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.32
    114425:20230221:120537.301 7f0f1336b000-7f0f1365c000 r--p 0015a000 103:01 5330                      /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.32
    114425:20230221:120537.301 7f0f1365c000-7f0f1365d000 ---p 0044b000 103:01 5330                      /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.32
    114425:20230221:120537.301 7f0f1365d000-7f0f13661000 r--p 0044b000 103:01 5330                      /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.32
    114425:20230221:120537.301 7f0f13661000-7f0f13953000 rw-p 0044f000 103:01 5330                      /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.32
    114425:20230221:120537.302 7f0f13953000-7f0f1395a000 rw-p 00000000 00:00 0
    114425:20230221:120537.302 7f0f1395e000-7f0f13962000 rw-s 00000000 00:01 9                          /SYSV00000000 (deleted)
    114425:20230221:120537.302 7f0f13962000-7f0f13963000 r--p 00000000 103:01 3457                      /usr/lib/x86_64-linux-gnu/ld-2.31.so
    114425:20230221:120537.302 7f0f13963000-7f0f13986000 r-xp 00001000 103:01 3457                      /usr/lib/x86_64-linux-gnu/ld-2.31.so
    114425:20230221:120537.302 7f0f13986000-7f0f1398e000 r--p 00024000 103:01 3457                      /usr/lib/x86_64-linux-gnu/ld-2.31.so
    114425:20230221:120537.302 7f0f1398e000-7f0f1398f000 rw-s 00000000 00:01 4                          /SYSV00000000 (deleted)
    114425:20230221:120537.302 7f0f1398f000-7f0f13990000 r--p 0002c000 103:01 3457                      /usr/lib/x86_64-linux-gnu/ld-2.31.so
    114425:20230221:120537.302 7f0f13990000-7f0f13991000 rw-p 0002d000 103:01 3457                      /usr/lib/x86_64-linux-gnu/ld-2.31.so
    114425:20230221:120537.302 7f0f13991000-7f0f13992000 rw-p 00000000 00:00 0
    114425:20230221:120537.302 7ffd5743e000-7ffd57460000 rw-p 00000000 00:00 0                          [stack]
    114425:20230221:120537.302 7ffd57591000-7ffd57595000 r--p 00000000 00:00 0                          [vvar]
    114425:20230221:120537.302 7ffd57595000-7ffd57597000 r-xp 00000000 00:00 0                          [vdso]
    114425:20230221:120537.302 ffffffffff600000-ffffffffff601000 --xp 00000000 00:00 0                  [vsyscall]
    114425:20230221:120537.302 ================================
    114425:20230221:120537.302 Please consider attaching a disassembly listing to your bug report.
    114425:20230221:120537.302 This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    114402:20230221:120537.310 One child process died (PID:114425,exitcode/signal:1). Exiting ...
    114402:20230221:120537.862 PROCESS EXIT: 114425
    114404:20230221:120537.863 HA manager has been paused
    114402:20230221:120537.943 syncing history data...
    114402:20230221:120537.966 [Z3008] query failed due to primary key constraint: [1062] Duplicate entry '74553-1676981133-2052651' for key 'PRIMARY'
    114402:20230221:120538.018 skipped 948 duplicates
    114402:20230221:120538.034 [Z3008] query failed due to primary key constraint: [1062] Duplicate entry '80397-1676981136-892578874' for key 'PRIMARY'
    114402:20230221:120538.050 skipped 278 duplicates
    114402:20230221:120538.060 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x38]. Crashing ...
