Only monitor processes when application is installed.
  • Fr1ts1e
    • Feb 2023
    I am looking to find a way to create an item that only starts monitoring a process when the application that usage that process is installed.
    For example some apache servers we have. The item should do something like when 'system.sw.packages[apache2]" is 1 then monitor the apache process.
    If "system.sw.packages[apache2]" = 0 then do nothing.
    Is this possible in Zabbix?
    Regards,
    Frits
    • 4970
    Discovery is the keyword you should look for in documentation...
    • Fr1ts1e
      • Feb 2023
      Looks like the systemd.unit.discovery is only supported under Zabbix Agent 2. We are unfortunately on a lower version.
        • 4970
        But you can always write your own scripts to do similar work... UserParameters are for such cases... Or install agent2 ... That's not really a "higher version". It is just a different version and can replace classic agent.
        You have options, just need to pick the one(s) you want to use...​
